InterAS MPLS Option C (BGP IPv4 + Labels) IOS XR with eBGP multihop session
Mar 13th, 2012
Right now we have InterAS MPLS Option C configured between 2 autonomous systems.
Now we need to add more bandwith and would like to add another interface between the two routers establishing a multihop session using loopbacks to load share traffic.
I know that IOS-XR does not automatically learn directly connected host routes so for the XR router to assign labels you'll need to configure a static host route to ensure MPLS forwarding to the neighboring AS.
This works with directly connected neighbors but when I try to enable the multihop session, the XR does not assign labels even configuring the staic host route.
Does anybody has a configuration like that working?
Thanks!!
Jose.
Average Rating: 0 (0 ratings)
vinijain Wed, 03/21/2012 - 18:34
Hello Jose
There are basically two options in Option C L3VPN setup. I will discuss the first option for Multihop.
Following are the key points that distinguish the InterAS Option C from previous options.
1) External Multihop BGP address families are invoked between two different autonomous systems; however, these eBGP sessions are invoked between the route reflectors in each AS and not on the ASBR. The route reflector in each AS thus passes labeled ipv4 unicast VPN routes to the other AS. Note:- The route reflector in this case will have PE clients in the vpnv4 address family within that Autonomous System.
2) ASBRs facilitate the creation of InterAS LSP by providing labeled /32s for PE and Route Reflector loopback.
3) This option enhances scalability because ASBRs do not handle VPNv4 routes in fact this option gets rid of the extra L3VPN LFIB that is created as a result of option B . The LFIB size is minimal as we control the redistribution to the only 2 needed loopback addresses (remote ASBR and remote RR)
Sample config of the RR:
router bgp 102
address-family ipv4 unicast
address-family vpnv4 unicast
neighbor-group ibgp
  remote-as 102
  update-source Loopback0
   route-reflector-client
neighbor 192.168.253.3
  remote-as 101
  ebgp-multihop 255
  description eBGP-RR-PEER-AS101
   route-policy allow-all in
   route-policy allow-all out
   next-hop-unchanged
neighbor 192.168.254.1
  use neighbor-group ibgp
neighbor 192.168.254.3
neighbor 192.168.254.4
On the PE router, the config will look something like this:
router bgp 102
  redistribute ospf 1 metric 3333 route-policy interAS-optionc-out
  allocate-label route-policy interAS-optionc-out
neighbor 65.10.20.1
  remote-as 101
  address-family ipv4 labeled-unicast
   route-policy interAS-optionc-in in
   route-policy interAS-optionc-out out
neighbor 192.168.254.2
  remote-as 102
router static
  65.10.20.1/32 TenGigE0/0/0/1
  192.0.2.0/24 Null0 tag 10
  if destination in remote-RR-PE then
    pass
  else
    drop
  endif
end-policy
  if destination in local-RR-PE then
    pass
  else
    drop
  endif
end-policy
prefix-set local-RR-PE
  192.168.254.2/32,
  192.168.253.6/32,
  192.168.253.5/32
end-set
prefix-set remote-RR-PE
  192.168.253.2/32,
  192.168.253.3/32,
  192.168.253.3/32
end-set
Just for your clarification, 192.168.253.0/24 is the Remote AS networks and 192.168.254.0/24 is the local AS networks.
Hope this clarifies your doubts.
Cheers ... !!!
Vinit
jbaraona Wed, 03/21/2012 - 20:07
Hello Vinit
Thanks for your response but I think I didn't explain the problem correctly. What you explained is correct as a matter of fact, I do have the configuration exactly that way.
Actually my problem is I need to add more bandwidth between Autonomus Systems. When I try to add another TenGig interface between ASBRs and configure the IPv4 session as multihop (to loadshare between de two TenGig interfaces), the 12k XR router does not assign labels to the 7609 on the remote AS.
I will let you know if I find a solution.
Thanks for your help.
regards,
Jose.
vinijain Wed, 03/21/2012 - 20:11
Hello Jose,
Thanks for the prompt reply. Let me know if you are not able to get anything on it. I shall be able to help you fix the issue.
let me know if you need any help related to XR or any other issue related to your setup.
Vinit
prdpvaghela Wed, 03/21/2012 - 22:46
Hi ,
In Option-C, how many labels are assigned to prefixes & what are they?
Pradip Vaghela
vinijain Wed, 03/21/2012 - 22:58
Hello Pradip,
In Option C, there are two methods:
1) PE loopbacks of the other AS are advertised in local AS via IGP ROUTES (redistributed from eBGP)
In this method two labels will be used:
     a) 1 for the VPN
     b) 1 for the PE loopback (like regular MPLS-VPN)
2) PE loopbacks of other AS are advertised in local AS via iBGP ROUTES
In this method three labels used
      a) 1 for the VPN
      b) 1 for destination PE (next-hop)
      c) 1 to get to the local ASBR
I am not mentioning about the local mpls ldp or TE labels (if present)
Hope this answers your question.
Vinit
gustavoa.guerra Thu, 03/22/2012 - 10:10
Jose
You may  find some useful information about Inter-AS Option C Multipath Load Balance Options here (Page 17):
http://blog.uruhu.su/sites/default/files/Cisco_I-AS-MPLS.pdf
HOSTNAME ASBR
interface e0/0
ip address 168.192.0.2 255.255.255.252
mpls bgp forwarding
! Enable BGP forwarding on connecting interfaces
interface e2 /0
ip address 168.192.2.2 255.255.255.252
mpls bgp forwarding
router bgp 2
neighbor 10.10.10.10 remote-as 1
neighbor 10.10.10.10 disable-connected-check
neighbor 10.10.10.10 update-source Loopback0
address-family ipv4
neighbor 10.10.10.10 activate
neighbor 10.10.10.10 send-label
ip route 10.10.10.10 255.255.255 e0/0 168.192.0.1
ip route 10.10.10.10 255.255.255 e2/0 168.192.2.1
Configure /32 static routes to the eBGP neighbor loopback address
But they only talk about IOS, may be you can visit this site, to convert IOS commands to IOX
http://www.cisco.com/en/US/docs/ios_xr_sw/iosxr_r3.5/xr12000_conversion/reference/guide/cn35main.html#wpmkr1183423
Kind regards
Gustavo
Login or Register to take actions
Posted March 13, 2012 at 11:52 AM
Stats:
Replies:8 Avg. Rating:
Views:4831 Votes:0
Shares:0
Tags: mpls, bgp, interas
Related Content
Discussions Leaderboard
