ISE and Auto Smartports
Mar 13th, 2012
  • Bronze, 100 points or more
I am testing ISE and Auto Smartports and i got the execution of the macro via ISE working.
However, it seems i MUST enable globally "macro auto global processing " before it the macro is really executed.
I would like to avoid this, as enabling this globally, it will automatically run all standard cisco macros for phones, AP, etc.
To prevent this, i need to configure "no macro auto processing" on each and every interface...
Isn't there another way to enable macros but not run the default macros on all ports. Only run -custom- macros when triggered by ISE ?
regards,
Geert
Alfonso Lopez Mon, 09/19/2016 - 08:10
Would you like to share the document that you followed to get Auto Smarports to work with a response from the ISE?
I can´t find anything where it is well explained.
