SPA50x and 525G Dual Registration
innovacrew
I noticed with the 7.4.9c firmware update that a new field exists called Dual Registration (yes/no) with each extension.  A Google search turns up nothing whatsoever.  What does this function do and how can it be used?
I am using DNS SRV records and I frequently have phones seemingly registering to both of my servers instead of just the highest priority server.  This is intermittent and I'm not sure why it's happening.  In a perfect world it would be great if the phone would register to both servers as it would make failover significantly better.
Josh
rbordner
Josh,
The option for dual registration  was added per a request from a specific service provider.
Please check with your ITSP if they support dual registration from a single endpoint.
Randy
