ASA 5505 DHCP ISSUE
Mar 14th, 2012
Hi ALL
i have to install an ASA 5505 and i need DHCP for more than 1000 ip addresses
i faced a problem when i am configuring a DHCP pool that i con not get more than 256 ip addresss from the dhcp pool
do i have to buy a license or upgrading new firware or what ???
please help
llamaw0rksE Fri, 03/23/2012 - 09:58
Does that mean 256 for BOTH the default basic inside LAN and the available DMZ, or 256 for EACH??
george@cleopatr... Sat, 03/24/2012 - 02:15
thank you Mirober and Alex for your replies
i have two inside LAN sides (guest and admin), for admin it's static IP but the problem with guest that i need to enable DHCP server to give them more than 1000 IP addresses
i have read from the documentation that i cannot create a DHCP pool for more than 254 ip addresses even if i have unlimited lisence
thank you
