Kimberly Adams Wed, 03/14/2012 - 10:06
  • Silver, 250 points or more
On the 5510 you can run 8.2(1), 8.2(2), 8.2(3), 8.2(4), and 8.2(5) versions of software.
Thanks and do rate helpful posts.
Kimberly
Kashish_Patel Wed, 05/30/2012 - 23:51
I have the same question as Muhammad. Can anyone please anwer it explicitly?
Can some one let me know if ASA 8.2 IOS is compatible with both ASA 5510  and ASA 5520. If i have 8.2 IOS running on ASA 5520, can the same IOS  be used for ASA 5510."
I see that the ASA image names are similar for all ASA platforms and the image size is also same across different ASA platforms.
Kashish
varrao Thu, 05/31/2012 - 00:02
  • Red, 2250 points or more
Hi Kashish,
The image is completely compatible with both ASA 5510 & 5520 firewalls, you can use the same image for both the platforms.
You can use the same image for all the platfom: ASA 5505,5510,5520,5540 & 5550
For ASA 558X- this platform uses a different image than the rest.
Varun Rao
Security Team,
Cisco TAC
Kashish_Patel Thu, 05/31/2012 - 00:08
Thanks Varun.
That answers my question. I am not able to mark this post as answered as I did not create it.
Kashish
varrao Thu, 05/31/2012 - 00:43
No Issues Kashish You can simply rate the post.
Varun Rao
Security Team,
Cisco TAC
