BGP Multihomed with single /24
Gerard Gacusan
If having a single /24 allocated address space, can i split this into smaller subnets so that half of the subnet preferred to ISP1 and half to ISP2 as the primary path respectively? and should there will be link failure, convergence routes via iBGP peer towards the peering ISP?
7 Replies 7
andrew.prince
Level 10
Level 10
why do you want to split it???? I have 4 data centres each advertise a single /24 to dual independent isp's works well for me, :o)
The idea behind of load-sharing the traffic  ...
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
For outbound, if your devices support it, have you examined OER/PfR?
yeah i'm using OER
darren.g
Level 5
Level 5
Most ISP's will not accept anything smaller than a /24 in advertisement - so no, you won't be able to advertise say a /25 out one ISP and another /25 out the other.
However, if you advertise the whole /24 to both uplinks at the same precedence, and without any prepending, then traffic will come in via the 'best" path from its originating point. That's about all you can do with incoming data, really - even if you prepend and give one link a much higher precedence, there will always be *some* traffic which will come in over the second link simply because the "path" to your terminating point is shorter.
If you want to control how your *outbound* data flows, then as Joseph has suggested, you should look into OER/PfR - I've explored this recently for a similar situation, and will be implementing it as soon as I can get a change window approved.
yeah i agree ... i tried prepending and bgp looking glass tells me the whole /24.
i advertised /24 on both ISP's and i have no problem with that.
Gerard Gacusan
You'll probably have this as well but just in case, here's a good read.
http://docwiki.cisco.com/wiki/PfR:Solutions
BGP community is an other option.
