Accessing a VPN though ASA5505
Mar 15th, 2012
I only have basic knowledge on Router configurations, so  please help me figure out what I have to do. I want to settup a IPSec VPN from a computer to another network and connect remotedly to a client on the other side. The configuration is as follows:
WIndows 7 Computer --- ASA5505 --- (Internet) --- SA540 --- Network
Device 1:
Cisco SA540 Security Appliance (Small Business Pro)
Security Appliance Configuration Utility 2.1.71 Firmware
Device 2:
CISCO ASA5505 (Security Plus)
Usually each router is configured by a consultant, but for some reason they can't get the VPN connection to work. The consultants are not very willing to help either.  So I gotta figure this out by myself or get someone else to help. (hopefully I can figure it out)
At the moment I only have access to the ASA5505 router through ASDM and I am testing from the Windows 7 side using CISCO VPN client. My guess is that the problem is on the ASA5505 side because I can connect to the VPN if I use a Sprint 3g card, but as soon as I attempt to connect through the network, it fails to respond.
What sort of LOG or configuration would you need me to post in order to get help, judging by what I have access to...
Thank you in advance, every bit of help will be appreciated!
Related Content
