Question about VLAN Routing on SG200
Mar 15th, 2012
I know that the SG200 series has VLAN support but was wondering it would support VLAN routing within the switch itself.
Hypothetically if I wer eto configure the ports as following:
Ports 1-10 on VLAN 1
Ports 11-20 on VLAN 2
Ports 21-30 on VLAN 3
Can devices on all the ports talk to each other without needing to purchase additional networking equipment?
Thanks in advance for the help.
David Hornstein Thu, 03/15/2012 - 23:06
  • Gold, 750 points or more
Hi Tony,
The 200's can segment traffic into VLANs, but IP switching between VLANs can be achieved on the SG300 series and the older Sx500 series switches.
regards Dave
tonynguyen1 Thu, 03/15/2012 - 23:33
Thanks David.
If I go with the SG200, can I use the Cisco RV220W to route traffic between all the VLANS?
David Hornstein Fri, 03/16/2012 - 05:26
Hi Tony,
That is a solution, use a VLAN aware router such as a RV220W  to route between the SG200 VLANs.
For your information, if you are a Cisco Partner, you should have access to the Rv220W GUI emulator.
This is a great page for you to check out the management interfaces for both the 200 series switches and the RV220W.
https://supportforums.cisco.com/community/netpro/small-business/onlinedemos
The RV220W is a vlan aware product that can work with four configured VLANs. Hopefully that is enough.
regards Dave
David Hornstein Mon, 03/19/2012 - 07:21
Hi Tony,
I responded to that posting you referenced.
regards Dave
