Warning message
Bridge-Groups FWSM
Mar 15th, 2012
Hello All,
I have a question about Bridge Groups if someone can help me. So, I have two bridge groups on one FWSM obviously using two different IP Scopes. However I can only have one default route so for instance.
BVI 1 - 192.168.1.4 (outside1)
BVI 2 - 192.168.2.4 (outside2)
ip route outside1 0.0.0.0 0.0.0.0 192.168.1.1
I now obviously cannot put another default route statement in so how does the FWSM route traffic it doesn't know the destination to when the source is from 192.168.2.x. Does it send it out 192.168.1.1? If so does this become a suboptimal routing issue, and is there possibly a better solution than this? Or is thisnormal and everything is ok? Thanks in advance to all who reply!
mirober2 Fri, 03/23/2012 - 07:46
  • Cisco Employee,
Hi John,
When the FWSM uses bridge-groups, it is configured in transparent (layer 2) mode. Because of this, the FWSM won't be responsible for routing traffic. It will use a MAC address lookup instead:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm41/configuration/guide/fwmode_f.html#wp1232185
One exception to this is management traffic to/from the FWSM. For this, you'll need to specify separate static routes:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm41/configuration/guide/fwmode_f.html#wp1202704
"The default route for the transparent firewall, which is required to provide a return path for management traffic, is only applied to management traffic from one bridge group network. This is because the default route specifies an interface in the bridge group as well as the router IP address on the bridge group network, and you can only define one default route. If you have management traffic from more than one bridge group network, you need to specify a static route that identifies the network from which you expect management traffic."
-Mike
