Can't SSH into my 2911 Router from Outside Network
Mar 15th, 2012
Hi All!
   Got a strange problem here. We can't seem to SSH from the outside network into our router. Our router config looks straight forward enough. Can someone please take a look? Appreciate it!
-Tom
! Last configuration change at 10:41:22 zone Thu Mar 15 2012 by tssconsult
! NVRAM config last updated at 11:19:12 zone Thu Mar 15 2012 by tssconsult
version 15.0
hostname **********************
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication fail-message ^CCCLogin Failed Unauthorized access and use of this network will be vigorously prosecuted.^C
--More--                          aaa authentication login default local
aaa authentication login user local
aaa authentication login userauthen local
aaa authorization console
aaa authorization exec default local
aaa authorization exec con local
aaa authorization network stivpnusers local
aaa session-id common
clock timezone PST -8
clock summer-time zone recurring
no ipv6 cef
ip source-route
no ip gratuitous-arps
ip cef
--More--                          !
no ip dhcp use vrf connected
ip dhcp excluded-address 192.9.214.1 192.9.214.59
ip dhcp excluded-address 192.9.214.101 192.9.214.254
ip dhcp pool sdm-pool1
   import all
   network 192.9.214.0 255.255.255.0
   domain-name ***************
   default-router 192.9.214.50
   dns-server 8.8.8.8 4.2.2.2
ip flow-cache timeout active 1
no ip bootp server
ip domain name sbycab.com
ip name-server 68.238.64.12
ip name-server 68.238.96.12
ip inspect name myfw icmp
ip inspect name myfw tcp
ip inspect name myfw udp
ip inspect name myfw cuseeme
--More--                          ip inspect name myfw dns
ip inspect name myfw ftp
ip inspect name myfw h323
ip inspect name myfw https
ip inspect name myfw imap
ip inspect name myfw pop3
ip inspect name myfw netshow
ip inspect name myfw rcmd
ip inspect name myfw realaudio
ip inspect name myfw rtsp
ip inspect name myfw esmtp
ip inspect name myfw sqlnet
ip inspect name myfw streamworks
ip inspect name myfw tftp
ip inspect name myfw vdolive
crypto pki trustpoint TP-self-signed-1413036665
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1413036665
--More--                           revocation-check none
rsakeypair TP-self-signed-1413036665
crypto pki certificate chain TP-self-signed-1413036665
certificate self-signed 01
30820253 308201BC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
    quit
license udi pid CISCO2911/K9 sn *******************
username ******************* privilege 15 secret 5 **************************
redundancy
ip ssh time-out 30
ip ssh authentication-retries 2
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key ***************************** address 0.0.0.0 0.0.0.0
--More--                          crypto ipsec transform-set strong esp-3des esp-md5-hmac
mode transport
crypto ipsec transform-set newset esp-3des esp-sha-hmac
mode transport
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto ipsec profile cisco
set security-association lifetime seconds 120
set transform-set newset
bridge irb
interface Tunnel0
bandwidth 1000
ip address 2.2.2.3 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp authentication ****************
ip nhrp map multicast dynamic
--More--                           ip nhrp map 2.2.2.1 ****************
ip nhrp map multicast *********************
ip nhrp network-id 1
ip nhrp holdtime 300
ip nhrp nhs 2.2.2.1
ip tcp adjust-mss 1360
no ip split-horizon eigrp 90
tunnel source GigabitEthernet0/2
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile cisco
crypto ipsec df-bit clear
interface GigabitEthernet0/0
description Inside Network
ip address 192.9.214.50 255.255.255.0
ip flow ingress
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
--More--                          !
interface GigabitEthernet0/1
ip address 172.22.23.6 255.255.255.252
ip flow ingress
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/2
ip address *******************  255.255.255.248
ip flow ingress
ip nat outside
duplex auto
speed auto
no cdp enable
router eigrp 90
network 2.2.2.0 0.0.0.255
--More--                           network 192.9.214.0
no eigrp log-neighbor-changes
router rip
version 2
redistribute connected
redistribute eigrp 90 metric 1
network 172.22.0.0
no auto-summary
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination ********************
ip nat inside source list 10 interface GigabitEthernet0/2 overload
ip route 0.0.0.0 0.0.0.0 ********************
--More--                          access-list 10 permit 192.9.214.0 0.0.0.255
snmp-server community y3r3Van! RO
snmp-server ifindex persist
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps eigrp
snmp-server enable traps tty
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps flash insertion removal
--More--                          snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps bgp
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps config-copy
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps event-manager
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps vtp
--More--                          snmp-server enable traps ipsla
snmp-server enable traps firewall serverstatus
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server host ***************************
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner motd ^CC
# WARNING: You are connected to a Secure Network                             #
# Unauthorized access and use of this network will be vigorously prosecuted. #
--More--                          ###############################################################################
^C
line con 0
exec-timeout 30 0
privilege level 15
logging synchronous
login authentication con
transport preferred none
transport output none
line aux 0
line vty 0 4
exec-timeout 30 0
privilege level 15
password 7 **************
logging synchronous
transport input ssh
scheduler allocate 20000 1000
webvpn context Default_context
ssl authenticate verify all
--More--                           !
no inservice
end
Marvin Rhoads Thu, 03/15/2012 - 19:33
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
The config appears to be set up to allow ssh to the vty. Has it ever worked? What are you seeing from your client when you try?
milkboy33 Thu, 03/15/2012 - 20:10
Yea SSH is not a problem from any of our internal network. We could also SSH to it while on the router to it's external IP.
The only problem is trying to SSH to it on it's external IP from anywhere OUTSIDE. There is no firewall on the outside interface. It connects directly to the ISPs equipment.
Marvin Rhoads Fri, 03/16/2012 - 03:56
  • Hall of Fame,
Strange. It looks an awful lot like an upstream (ISP) access-list preventing ssh. Your router obviously allows it and there's nothing in the config you posted to restrict it.
SergeyWinda Fri, 03/16/2012 - 05:01
So, with default factory settings it must accept incoming ssh connections from external sources?
Marvin Rhoads Fri, 03/16/2012 - 07:59
  • Hall of Fame,
Yes, as long as the router or switch is running an image with cryptographic support ("k9" in image name) and you have generated an RSA key for ssh, it will accept all ssh login requests (in the absence of any access list or firewall setting to prohibit them) and evaluate the credentials presented for login based on the authentication methods configured on the device.
Dennis Leon Mon, 05/07/2012 - 15:52
Has anyone solved this problem? I have a similar situation....My router has two interfaces; one connecting to the WAN of the network, from where I can SSH into it when I connect via VPN to the network. But the router has another interface directly connected to the Internet and I cannot SSH to that interface (I tried with and without VPN connection, there is a split tunneling rule, anyways, so this should not be a problem).
The default route is pointing to the Internet and I also created an ACL for monitoring purposes on the Internet's interface and it shows the SSH packets hitting the interface.
The SSH debugs are not really helpful tough....Any insights?
Thanks.
