Cisco AnyConnect NAM wireless issue
Mar 15th, 2012
We are currently working on deploying NAM into our Secure Mobility Client. We've found that this works beautifully on some machines and chokes horribly on others. Windows XP has a higher success rate than our Win 7 images. I have a particular user who has NAM installed (version 3.0.5075) who can no longer connect to our wireless network, which uses WPA2/AES and RADIUS authentication to an ACS server. If I disable the NAM client in Anyconnect, Windows relinquishes control and will allow the user to connect; as soon as I enable NAM, the wireless supplicant just keeps showing "Associating" and I do not see anything on the wireless controller or ACS logs so this user is not even getting that far. So far, I've tried pushing a new NAM profile through ASDM, deleting and recreating the configuration file in C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Network Access Manager\system, and multiple network repairs. There doesn't seem to be much in the way of documentation that I could find to assist in troubleshooting.
I have created a DART bundle and can attach if it would be helpful to someone to provide assistance. I've found this peculiar piece within the bundle:
601: SAMUSARAN: Mar 15 2012 12:10:56.732 +0500: %NAM-6-INFO_MSG: %[tid=5960]: Symbolic name: ({824DC894-2E9B-4929-A7A6-F6B8EEC18AA6}), MacAddr: (0024d6-09ef24), Mtu: (1514), Media: (802.11abg), Encryption: (AES, TKIP, WEP, NONE), Auth: (OPEN, SHARED, WPA-1X, WPA-PSK, 11i-1X, 11i-PSK)
602: SAMUSARAN: Mar 15 2012 12:10:56.732 +0500: %NAM-6-INFO_MSG: %[tid=5960]: Starting wifi connection, trying ssid zebes ...
180: SAMUSARAN: Mar 15 2012 12:10:56.732 +0500: %NAMSSO-7-DEBUG_MSG: %[tid=8672]: Tx Msg: <?xml version="1.0" encoding="UTF-8"?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ssc="http://www.cisco.com/ssc" encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <SOAP-ENV:Body>  <networkStateEvent>   <sequenceNumber>52</sequenceNumber>   <groupName>Local networks</groupName>   <networkName>zebes</networkName>   <networkState>Stopped</networkState>   <adapterName></adapterName>   <serverVerifiedName></serverVerifiedName>  </networkStateEvent> </SOAP-ENV:Body></SOAP-ENV:Envelope>
603: SAMUSARAN: Mar 15 2012 12:10:56.733 +0500: %NAM-6-INFO_MSG: %[tid=5960]: Connection Association Started(wpa2EnterpriseAes)
604: SAMUSARAN: Mar 15 2012 12:10:56.756 +0500: %NAM-3-ERROR_MSG: %[tid=5960][comp=SAE]: NET (0) ***ERROR: S_nwifiConnect: WlanConnect() returned 1399: HANDLE=45, GUID*=00773148 {824DC894-2E9B-4929-A7A6-F6B8EEC18AA6}, WLAN_CONNECTION_PARAMETERS dump follows
605: SAMUSARAN: Mar 15 2012 12:10:56.756 +0500: %NAM-3-ERROR_MSG: %[tid=5960][comp=SAE]: NET (0) 0000  01 00 00 00  88 F8 7C 00  00 00 00 00  00 00 00 00  01 00 00 00  00 00 00 00                            ......|.................
606: SAMUSARAN: Mar 15 2012 12:10:56.756 +0500: %NAM-3-ERROR_MSG: %[tid=5960][comp=SAE]: NET (0) Failed to set SSID
607: SAMUSARAN: Mar 15 2012 12:10:56.756 +0500: %NAM-3-ERROR_MSG: %[tid=5960]: Connection Association Failed (Failure: AC_ERR_FAILURE[-1])
608: SAMUSARAN: Mar 15 2012 12:10:56.756 +0500: %NAM-3-ERROR_MSG: %[tid=5960]: Internal error 4, contact software manufacturer
609: SAMUSARAN: Mar 15 2012 12:10:56.756 +0500: %NAM-7-DEBUG_MSG: %[tid=5960]: CssError for function 'acPortAssociate' => -1{error} [PortManagerImpl.cpp:169]
610: SAMUSARAN: Mar 15 2012 12:10:56.756 +0500: %NAM-7-DEBUG_MSG: %[tid=5960]: AssociationInfoProxy is empty
611: SAMUSARAN: Mar 15 2012 12:10:56.762 +0500: %NAM-7-DEBUG_MSG: %[tid=5960]: Network zebes: AccessStateMachine current state = ACCESS_ASSOCIATING, received adapterState = associating
612: SAMUSARAN: Mar 15 2012 12:10:56.762 +0500: %NAM-7-DEBUG_MSG: %[tid=5960]: Network zebes: AccessStateMachine new state = ACCESS_ASSOCIATING
613: SAMUSARAN: Mar 15 2012 12:10:56.762 +0500: %NAM-7-DEBUG_MSG: %[tid=5960]: Network zebes: NetworkStateMachine current state USER_T_DISCONNECTED, received access event ACCESS_ASSOCIATING
614: SAMUSARAN: Mar 15 2012 12:10:56.762 +0500: %NAM-7-DEBUG_MSG: %[tid=5960]: Network zebes: NetworkStateMachine new state USER_T_DISCONNECTED
615: SAMUSARAN: Mar 15 2012 12:10:56.762 +0500: %NAM-7-DEBUG_MSG: %[tid=5960]: Entered AceStateMachineImpl::handleEvent in state Configuration::STARTED: processing AccessSM state change to Network::ACCESS_ASSOCIATING
616: SAMUSARAN: Mar 15 2012 12:10:56.763 +0500: %NAM-7-DEBUG_MSG: %[tid=5960]: Number of networks in connecting state = 1
Etts Equinox Thu, 12/10/2015 - 02:45
i have the same problem.
i get the same error Failure: AC_ERR_FAILURE[-1]
can anyone have a solution for this issue
thanks
