C2960 IOS 12 or 15? (layer 3)
Answered Question
Mar 16th, 2012
Hi We have just had a cisco 2960 delivered wich is being used for its basic layer 3 functionality. I was wondering would I still beable to use this if I upgrade to version 15? I was also wondering what this version 15 is all about and if there are any big differences in the command set as ive onyl ever worked with the 12. revisions before?
James
Correct Answer by Peter Paluch about 5 years 1 month ago
Hi James,
Alex has summed it up nicely. Basically, Cisco appears to be consolidating its versioning of different IOSes, and as part of this consolidation, the IOS versions for Catalysts have been bumped from 12.2 to 15.0. However, the 12.2(58)SE and 15.0(1)SE are practically identical, save for a couple of new features and bugfixes (and perhaps a couple of new bugs being introduced ).
Best regards,
Peter
Correct Answer by acampbell about 5 years 1 month ago
Looking at the config guide for IOS 15.0.0
This was also the same on 12.2.58
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/15.0_1_se/configuration/guide/swipstatrout.html
Static routing is supported not dynamic.
Also only on SVI not port level
Alex
Overall Rating: 5 (4 ratings)
davy.timmermans Fri, 03/16/2012 - 05:08
  • Silver, 250 points or more
Hi James
As far as I know - the 2960 model is a pure layer 2 switch with one SVI (L3 vlan interface) which is used for management purposes.
Peter Paluch Fri, 03/16/2012 - 05:16
  • Cisco Employee,
Davy,
As surprising as it may seem, the inter-VLAN routing and static IP routing has been introduced to 2960 series Catalysts sometime after 12.2(52)SE. So having a fairly recent IOS, the 2960 do support basic inter-VLAN routing and static routing but no routing protocols.
Best regards,
Peter
Leo Laohoo Fri, 03/16/2012 - 05:22
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Yes it does.  Starting from 12.2(55)SE3 (and later).
New Software Features
When you configure the new lanbase-routing  SDM template, the switch supports static routing and router ACLs on SVIs. ( Catalyst 2960, 2960-S, and 2975)
Correct Answer
Peter Paluch Fri, 03/16/2012 - 05:23
  • Cisco Employee,
Hi James,
Best regards,
Peter
jamessmart747 Sat, 03/17/2012 - 04:49
Thanks Peter that is basically what I wanted to know. I did not understand the jump from 12 to 15 and was thinking i may be a different config set, but this makes snese so thanks
jamessmart747 Sat, 03/17/2012 - 04:50
Thanks guys for the replys, I now have a better understanding of this new versioning.
James
