Warning message
Management Homepage on all Ports from 4 Switches (1 VLAN)
Hello!
I´m new in the cisco branche.
I can only connect to the Management Homepage over the Management Port! - But i will connect it over all Ports (1-24; or 1-48) to the Management Homepage from all Switches.
Here is the Situation:
I have two 3750X in a Stack (with two 10G SFP+ modules) an from this stack i connected two 2960S crossover.
So i get:
3750x Stack
Master Port 1     <-> 2960_1 Port 1
Master Port 2     <-> 2960_2 Port 1
Slave Port 1       <-> 2960_2  Port2
Slave Port 2       <-> 2960_1  Port2
I have only one VLAN, and this is the default VLAN.
I define on all Switches the Management Port (FastEth0) to a Management IP adress - i can Connect with the Notebook an it Works fine!
I give the 3750X Stack     the IP 10.10.30.230 with Mask /24 on (VLAN1)
I give the 2960s_1           the IP 10.10.30.231 with Mask /24 on (VLAN1)
I give the 2960s_2           the IP 10.10.30.232 with Mask /24 on (VLAN1)
All Switches have the Gateway 10.10.30.254 and DNS 255.255.255.255
I cannot connect the Management Homepage with the 10.10.30.231 or 232.
I Would like to connect with the Manag. Homepage from the 2960_1 over the 10.10.30.231; an the 2960_2 over the 10.10.30.232.
What i have to do?
THANKS!
Related Content
