Cisco 8945 Video Call
scooter817
Level 2
Level 2
Hi everyone, I wanted to know can someone tell me how do I configure the 8945 phone to do a video call.
We have 5 of them that we just bought for our executives and they want to be able to make video calls from
the phone. I've looked for documentation on it and all i keep coming up with is the phone's user guide. And
the guide keeps saying "Connects to your Cisco Unified IP phone and allows you to make point to point video
calls with another Cisco Unified IP phone.So if anyone can help me out I would really appreciate it and thanks
in advance for the help and have a great weekend.
No, just eliminating Call Admission Control as an issue.
Is the video setting disabled on the phone by any chance, physically on the phone go to the video settings and review the config there.
Chris
9 Replies 9
Chris Deren
There is nothing you need to do except making sure video is enabled on the phone config page which should be on by default.
HTH,
Chris
Chris
I went into CM and and found the phone and went into the phone configution page for that device and went to product specific configuration layout.I checked and the video capabilities option is checked.
The only thing that I see is the self view option on the phone so should I do something after I turn on the self view option
So, when one 8945 calls another 8945 you get no video?
Are they defined to be in the same DP?
Chris
They are in the same device pool as all of our other phones we have,should these particular phones have there own device pool?
Chris
Thanks Chris
I will go to work tomorrow and check this out and I will let you know
You know Chris I don't know what's wrong with this,because I've checked and everything seems right. I also went to You tube and watched a demo of how it works and your right I should just start working.
I don't know if this has been resolved or not, but I would suggest checking the Video Call Admission Control Bandwidth settings on the Region page.  Even if they are in the same Device Pool, and therefore, same Region, it is possible to configure a Max Bandwidth even within the current Region and that setting can be 0.
