UC320w and fax
Mar 17th, 2012
We have a fax machine that we woudl like to connect awya from the UC320 and woudl like to use a gateway to convert ethernet (or wifi) to connect it and have it close to the secretary.  Which gateway can do this that you recommend?  Any other hints or suggestions woudl be great.
Alaeddin
Alberto Montilla Sat, 03/17/2012 - 03:34
  • Cisco Employee,
Hi Alaeddin;
For Ethernet, option is to use the SPA8800.
Alberto
saftool72 Sat, 03/17/2012 - 04:49
Thanks for the reply.  It seems the SPA8800 is over kill for me and costs almost asmuch as the UC320w.  all I need is to connect a fax to a gateway away from the UC320.  something like the
SPA2102
Woudl that work for this purpose?
rbordner Mon, 03/19/2012 - 10:24
  • Cisco Employee,
Saf,
The firmware on the SPA2102 does not support the features from the UC320W.  The SPA8800 is the fxo/fxs gateway to date.
Reagrds,
Randy
