Warning message
TAPS isn't working. Dead Air
Mar 17th, 2012
I'm working with CUCM 7.1.5 and UCCX 8.0 and have properly configured the TAPS on the both sides.
When I dial the Route Point number, the caller hears dead air. The caller hears no  ringback prompts, such as a busy tone or an engage tone.
When I have installed the UCCX 8.0, I have choosed to use G.711 and the phone is using G.711 to dial CCX.
Anyone already had the same issue or know how to fix that?
Thank you and I really appreciate
anchoudh Sat, 03/17/2012 - 19:32
  • Red, 2250 points or more
Hi Jefferson,
Please chek the below link and troubleshooting tips gievn under UCCX 8.0.
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a008084321e.shtml
Were you able to make atleast one succesful call from any other caller phone?
Restart the TAPS service on the CUCM Publisher , along with restarting Engine of UCCX .
Check for the TAPS route point associated Call Control group and its CTI ports status in CUCM.
Did you upgrade your call manager after the TAPS is installed ?
You can try reinstalling the TAPS (dudring non-productions hours) and give a try.
Hope it helps.
Anand
Please rate helpful posts..
Jefferson Islan... Mon, 03/19/2012 - 07:01
Everything is configured properly. I already did a UCCX reinstall but the issue still going on.
Everything seems OK, but still not working.
Do you have any troubleshooting suggestion?
Aaron Harrison Mon, 03/19/2012 - 07:03
  • Community Spotlight Award,
    Member's Choice, May 2015
Dead air on this generally means a problem with the language; i.e. Iv'e set the server to UK english and TAPS isn't set up for UK.
Try setting the trigger language to US and see if you get something...
Aaron
anchoudh Mon, 03/19/2012 - 07:23
Hi Jefferson,
Could you please perofrom of uploading the TAPS.aar file one more time by downloading the TAPS.aar file from the current CUCM , and upload it from the UCCX aar management page and overwrite the existing files, and check it.
Anand
Jefferson Islan... Tue, 03/20/2012 - 06:46
Hi Aaron,
After I changed the Language to English / US everything is working properly. Do you know how I can work with Portuguese language?
anchoudh Wed, 03/21/2012 - 07:40
Hi Jefferson,
If you are referecning to TAPS.aar file uploading in UCCX.
First download this TAPS.aar file from CUCM plugin page.
Login into UCCX admin, navigate to applications-> AAR management and point it to to this TAPS.aar file and upload it, if its already uploaded once before you can say overwrite it, this will populate the UCCX script, prompts, and grammers in its respective paths. and you are good to go.
You can use the winrar software to extract the contents of TAPS.aar file.
Hope it helps.
Anand
Jefferson Islan... Wed, 03/21/2012 - 07:45
TAPS is already working properly, but only in US language. When I set to Portuguese, the call has no dial tone.
How I can play Portuguese prompts?
anchoudh Wed, 03/21/2012 - 07:59
Adding Languages for TAPS Prompts
To set the languages for TAPS prompts, use the following procedure.
Procedure
Step 1  In the Cisco CallManager Administration window, choose Bulk
Administration > TAPS > User Locales for TAPS. The User Locales
Configuration window displays.
Step 2 In the User Locales list box, which is the list of languages that
are installed on Cisco CallManager, choose the languages that you want
to use for user prompts. Click the arrow to move the chosen language to
the Selected User Locales list box.
You can choose as many languages as you need for user prompts and move
them to the Selected User Locales list box.
Step 3 After you have chosen the languages for user prompts, to create a
job, click Submit.
Step 4 Use the Job Scheduler option in the Bulk Administration main menu
to schedule and/or activate this job.
This procedure assumes you have already loaded the language packs onto
your CallManager.
Hope it helps.
Anand
