Warning message
Cat 6509- VSS - Minor Error (Sup module)
Mar 18th, 2012
Hi Guys,
We have a VSS environment with two Cisco 6509-Es.
IOS image:s72033-ipservicesk9_wan-mz.122-33.SXI5
when I switch on or reload the  Core switches(VSS), I find a Minor Error in the "Show module switch all" command.
I also did a "show diagnostic result switch 1 module 5"
Switch 1 Module 5: Supervisor Engine 720 10GE (Active)  SerialNo : SAL1521E035
  Overall Diagnostic Result for Switch 1 Module 5 : MINOR ERROR
  Diagnostic level at card bootup: complete
  Test results: (. = Pass, F = Fail, U = Untested)
   45) TestVslLocalLoopback:
      Port  1  2  3  4  5
            U  U  U  .  F
This issue temporarily relieves when reseating the X2 module, but reappears after reloading the switch.
Any comments/Suggestions are highly appreciated.
Siby.
Overall Rating: 4 (1 ratings)
Leo Laohoo Sun, 03/18/2012 - 01:42
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
RMA the module.  If it's re-occurs then rest assured, something sinister is happening.
siby.thomas Sun, 03/18/2012 - 04:10
Many thanks for the reply..
When I reload some times the Minor error appears and sometimes not.
Still do you think this could be a Hardware issue?
Reza Sharifi Sun, 03/18/2012 - 08:30
    2017 LAN
If the issue disappears when you reseat the X2 module, then replace the X2 module first. I am assuming you are referring to the X2 modules on the Sup right?
siby.thomas Tue, 03/20/2012 - 06:10
Hi Reza,
Thanks for the reply,
Let me re-create the problem and confirm this.
Leo Laohoo Sun, 03/18/2012 - 14:08
  • Hall of Fame,
    2017 LAN, Wireless
Yes I do.
