03-19-2012 03:17 AM - edited 03-07-2019 05:38 AM
Can any one explain me how VRF works
recently i am configuring a 4500 e series switch iam no able to ping the switch from my laptop.But iam able to ping it from other switches can any one tell me why
the command i found on the switch is IP VRF MGNT-VRF
03-19-2012 04:05 AM
VRF stands for virtual routing and forwarding. When you create a vrf, you tell it what routes to import/export. Then you assign that vrf to an interface. Once the vrf is attached to an interface, the switch/router creates a separate routing table to hold those routes. To see those, you'd type "sho ip route vrf MGNT-VRF".
VRF are used in MPLS and VRF-Lite implementations. So a vrf would look like this:
ip vrf MGNT-VRF
rd 100:100
rt export 100:100
rt import 100:100
ip vrf Red
rd 200:200
rd both 200:200 (export and import)
Under the interface:
int g0/1
ip vrf forwarding Red
ip address 192.168.200.1 255.255.255.0
int g0/2
ip vrf forwarding MGNT-VRF
ip address 192.168.100.1 255.255.255.0
Any global address that you have on your switch will still be in what's now called the "global routing table" and any addresses assigned to the above 2 customers are in their respective VRF.
HTH,
John
03-19-2012 06:46 AM
John,
I guess that what you wanted to say but isn't clear is that the VRF is a separate routing table within a router. VRFs are to a router what VLANs are to a switch. Using VRFs, it is possible to virtualize a single router into several instances, each of them being (relatively) independent of each other, allowing for overlapping subnets, separate instances of routing protocols, separate set of interfaces assigned to each VRF, etc.
Best regards,
Peter
03-19-2012 07:04 AM
"Once the vrf is attached to an interface, the switch/router creates a separate routing table to hold those routes."
I thought I said that here...
Either way, the OP stated that it wasn't working while pinging to the switch from a connected host, but can from another switch. Chances are the vrf that the user is in isn't importing the route that the vrf MGNT-VRF is exporting OR the user isn't in a vrf and the management address is which would then need to leak the address in the global routing table. Correct?
03-14-2019 01:23 PM
03-15-2019 04:01 AM
It is Virtual Route forwarding, we use when we need a different routing table on the same device.
With this you can use same bunch of IP address and routing that you are using on default vrf, to segregate the customers using same IP.
There are many uses of vrf that you can find on cisco docs. Go through them.
