Warning message
Assigning IPv6 address to the Switch
Mar 19th, 2012
Hi Experts,
I'm new to IPv6 and have some doubt on configuration.
I have a 4500 switch which is supposed to get a IPv6 address via dhcp from a linux machine.
On the linux machine I have configured a pool on the /64 prefix and it handsover ip to the 4500 switch.
the problem is: although I have configured /64 prefix on my Linux PC, the switch always gets the IP on the /128 prefix so because of that i'm unable to ping the dhcp server from the client (Switch).
an I doing something wrong with my configuration
My configuration on the switch is as follows:
Switch#sh run int gig1/1
Building configuration...
Current configuration : 100 bytes
interface GigabitEthernet1/1
no switchport
ip address dhcp
ipv6 address dhcp
ipv6 enable
end
The logs says the following:
Switch#
*Mar 19 06:14:19.073: IPv6 DHCP: Sending RELEASE to FF02::1:2 on GigabitEthernet1/1
*Mar 19 06:14:19.073: IPv6 DHCP: DHCPv6 address changes state from OPEN to RELEASE (ADDR_SHUTDOWN) on GigabitEthernet1/1
*Mar 19 06:14:20.109: IPv6 DHCP: IPv6 not ready on GigabitEthernet1/1, message not sent
*Mar 19 06:14:21.165: IPv6 DHCP: IPv6 not ready on GigabitEthernet1/1, message not sent
*Mar 19 06:14:23.241: IPv6 DHCP: IPv6 not ready on GigabitEthernet1/1, message not sent
*Mar 19 06:14:27.189: IPv6 DHCP: DHCPv6 address changes state from RELEASE to IDLE (ADDR_TIMEOUT) on GigabitEthernet1/1
*Mar 19 06:14:28.505: %SYS-5-CONFIG_I: Configured from console by console
*Mar 19 06:14:35.789: IPv6 DHCP: Sending SOLICIT to FF02::1:2 on GigabitEthernet1/1
*Mar 19 06:14:35.793: IPv6 DHCP: Received ADVERTISE from FE80::225:B3FF:FEC9:5F5A on GigabitEthernet1/1
*Mar 19 06:14:35.793: IPv6 DHCP: Adding server FE80::225:B3FF:FEC9:5F5A
*Mar 19 06:14:36.865: IPv6 DHCP: Sending REQUEST to FF02::1:2 on GigabitEthernet1/1
*Mar 19 06:14:36.865: IPv6 DHCP: DHCPv6 address changes state from SOLICIT to REQUEST (ADDR_ADVERTISE_RECEIVED) on GigabitEthernet1/1
*Mar 19 06:14:36.865: IPv6 DHCP: Received REPLY from FE80::225:B3FF:FEC9:5F5A on GigabitEthernet1/1
*Mar 19 06:14:36.865: IPv6 DHCP: Processing options
*Mar 19 06:14:36.865: IPv6 DHCP: Adding address 2001:DB8:0:F101::AEAE/128 to GigabitEthernet1/1
*Mar 19 06:14:36.865: IPv6 DHCP: T1 set to expire in 3600 seconds
*Mar 19 06:14:36.865: IPv6 DHCP: T2 set to expire in 7200 seconds
*Mar 19 06:14:36.865: IPv6 DHCP: DHCPv6 address changes state from REQUEST to OPEN (ADDR_REPLY_RECEIVED) on GigabitEthernet1/1
*Mar 19 06:14:37.829: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet1/1 assigned DHCP address 192.168.0.7, mask 255.255.255.0, hostname Switch
Any reason why is it always assigning an ip address from the /128 mask?
Thanks for your help in advance.
-Vijay
