Connectivity problem after adding a second WLC
Mar 19th, 2012
I have a client with two identically configured WLC's running 7.0.230.0 with approximately 370 AP's.  We are currently testing before going into production and found that once the 2nd WLC comes online (same mobility/RF group), the clients are no longer able to connect / obtain an IP address.  We removed all security and still had the same issue when the 2nd controller came online.   This sounds like a bug and I'm thinking about upgrading to 7.2x, however, that requires upgrading the MSE/NCM.  Although I don't mind doing this upgrade, I was just wondering if anyone else has ran into this issue.
I did run both configuration files through the WLC Config Analyzer and nothing seems to jump out other than some typical RF issues.
Bob
s.vosper Tue, 03/20/2012 - 03:23
Bob
Have you checked to make sure you don't have any IP address duplications between any of the interfaces of the controllers?
Simon
Bob Bagheri Tue, 03/20/2012 - 10:19
Simon,
No IP Conflicts. Ironically, when we broke the Mobility Group, everything is working fine and clients are able to obtain their IP addresses from the DHCP servers.
Re,
Bob
Stephen Rodriguez Tue, 03/20/2012 - 10:21
  • Purple, 4500 points or more
Is the WLAN anchored?
Stephen Rodriguez Tue, 03/20/2012 - 11:59
Can you post the configs? Feel free to scrub them so bling as we have the mobility interface and WLAN configs.
Steve
Bob Bagheri Tue, 03/20/2012 - 15:18
It appears the MFP on the AP's was off on one controller.
Thanks for trying to help.
Re,
Bob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
