ACS 5.3 integration with cisco management tools
Mar 19th, 2012
I have a cisco ACS 5.3 appliance , I want to use it for authenticating (tacacs protocol) user access for the following systems :
LMS 4.1
WLC 5500 series
NCS
I have had partial success configuring the authentication , most of the problem is in the ACS side , as I understand it I need to
take the "user tasks" from the system , copy past it to the ACS in the policy elements , I tried it but it didnt work
I know I didnt give many detailes , I didnt want to write 3 pages .  basically I am looking for reference to cisco documents as I couldnt find
exactly what I was looking for
I will be happy to provide more specific information
thanks
Dev Vishwakarma Thu, 03/22/2012 - 05:34
  • Cisco Employee,
Nir,
You can use following:
1] wlc --
http://www.cisco.com/en/US/partner/tech/tk722/tk809/technologies_configuration_example09186a0080782507.shtml
2] ncs --
http://www.cisco.com/en/US/partner/products/ps6305/products_tech_note09186a0080b904a4.shtml
3] lms -- cisco works can not be directly integrated with ACS 5.x. Although you can send a normal authentication request to the ACS.
Dev
