CUCM - Two SIP Trunk with Same Destination
Mar 20th, 2012
Hi ,
We configure the  Two SIP trunk with Service Provider.One is for G711u codec another one for G729 codec.
There is no issue in the Outbound calls.
We have the problem in Incoming calls when the Service Provider send the call with g711 codec ccm select g729 trunk always.
Any one can explain the Incoming call behaviour for this scneario with any refernce document.
Thank
Gajanan Pande Tue, 03/20/2012 - 00:12
  • Cisco Employee,
Sriram,
To understand better, could you explain the call flow ? i.e. where the call comes from & where it goes ?
GP.
gpsriramdc Tue, 03/20/2012 - 00:16
Hi ,
Call flow will be
Remote Site   ---> SBC ---> CUBE ---> CUCM    ( CUBE to CUCM two SIP trunks)
Jonathan Schulenberg Tue, 03/20/2012 - 03:29
  • Cisco Designated VIP,
    2017 IP Telephony
CUCM will choose the SIP trunk based on the IP address in the FROM/VIA header of the SIP INVITE. Be sure that you are binding the outbound VoIP dial-peers on CUBE to separate loopback interfaces to allow CUCM to tell the difference.
Also be sure that the two SIP trunks in CUCM have different regions assigned and that your region matrix is properly configured to use a 64kbps codec with everything to/from that region.
