How I can block outgoing calls to specific number?
Answered Question
Mar 16th, 2012
Hello to all!
I want to block outgoing calls to list of specific numbers:
  • 08444 639595
  • 08719 977373
  • 08444 206464
  • 08717 704646
  • 09115 022525
  • 08444 660620
  • 09119 210220
  • 09112 070120
How I can do this?
Thanks to all!
Correct Answer by Jefferson Islan... about 5 years 2 months ago
Hi Maximo, how are you?
Use the reject keyword to reject calls that match. This example rejects all calls that start with "234".
rule 1 reject /^234/
router#test voice translation-rule 10 1234
1234 Didn't match with any of rules
router#test voice translation-rule 10 2345
 blocked on rule 1
Apply Rules
Voice Translation Rules are applied to Voice Translation Profiles.  These profiles are then applied to dial peers or voice ports. Profiles  can be applied to VoIP or POTS dial peers or voice ports, and can be  applied to inbound or outbound calls. A profile can translate Called,  Calling, or Redirecting numbers.
voice translation-rule 3
 rule 1 /123/ /456/
voice translation-profile profile1
 translate calling 3
dial-peer voice 10 pots
 translation-profile outgoing profile1
Please mark my reply as answered
Overall Rating: 4.5 (2 ratings)
Aaron Harrison Fri, 03/16/2012 - 05:02
  • Community Spotlight Award,
    Member's Choice, May 2015
CUCM? CME?
If CUCM, you can create route patterns to match each number (e.g. 908444639595) and set the route pattern to 'block this pattern'
Add them to your common internal partition (i.e. the one that DNs go in) if you have one to make it block system wide.
Aaron
Maximo Dominguez Fri, 03/16/2012 - 05:09
Hi aaronharrison, sorry for the miss information,
The system is a CME
Correct Answer
Jefferson Islan... Fri, 03/16/2012 - 05:21
 blocked on rule 1
Apply Rules
 rule 1 /123/ /456/
 translate calling 3
rvenkatesh7 Tue, 01/10/2017 - 23:11
Hi Jeff,
tried your solution but no luck it is not working.
Maximo Dominguez Tue, 03/20/2012 - 05:54
Hello to all,
I tried to configure Jefferson's solution, but I have an issue...
Mar 19 11:41:05.239: //-1/3AFC1059806E/RXRULE/regxrule_match: Skipping a call block rule; number=0644224569 rule precedence=1
I searched information about this issue and I deduced that it's not possible to use "rule X reject" with outgoing calls, this only works with incoming calls, it's true?
Also I tried to block number with COR, but here the problem is that the called number match with another dial-peer when the first try is blocked.
Example:
dial-peer cor custom
name local
name international
name movil
name oriol
dial-peer cor list local
member local
dial-peer cor list international
member international
dial-peer cor list movil
member movil
dial-peer cor list administracion
member local
member movil
dial-peer cor list helpdesk
member local
member movil
dial-peer cor list block
member oriol
dial-peer voice 11 voip
corlist outgoing local
description ### SIP Nacionales por VoipBuster por si falla/ocupado ANALOGICA
preference 2
max-conn 4
destination-pattern 0T
progress_ind setup enable 3
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
corlist outgoing international
description ### SIP Internacionales Voipbuster ###
preference 1
max-conn 4
destination-pattern 00T
dtmf-relay rtp-nte
no vad
dial-peer voice 50 pots
corlist outgoing block
description ### FXO ANTENA GSM SALIDA MOVILES ###
translation-profile outgoing SALIDA_CON_6_CELULAR
preference 1
destination-pattern 0644224569
port 0/2/1
ephone-dn  6  dual-line
number 400
pickup-group 830
label David Lopez 400
description David Lopez
name David Lopez
call-forward busy 899
call-forward noan 899 timeout 25
corlist incoming helpdesk
huntstop channel
hold-alert 30 originator
When I call from dn 400 the call is not possible via dial-peer 50, but the call is succes because CME uses dial-peer 11.
any idea?
Thanks!
Mohamed Ibrahim Fri, 04/12/2013 - 07:53
Hey Maximo,
I tried this but the call still goes out.
Can you help me please.
Mohamed Ibrahim Fri, 04/12/2013 - 08:22
Hey Chandan/Kamal,
My configuration
voice translation-rule 2
rule 1 reject /118118/
rule 2 /^9\(.*\)$/ /\1/
voice translation-profile Outbound
translate called 2
dial-peer voice 118118 pots
translation-profile outgoing Outbound
destination-pattern 118118
port 0/0/0:15
So Chandan you want me to remove the port number?
islam.kamal Fri, 04/12/2013 - 09:02
  • Red, 2250 points or more
hello
please use the below , i removed rule 2 /^9\(.*\)$/ /\1/  . For reject make it only in the voice translation rule. Please try
rule 1 reject /^118118/
translate called 2
port 0/0/0:15
Thank you
please rate if this will help
islam.kamal Fri, 04/12/2013 - 07:56
Hello
can you share your configuration? . What do you need exactly form your configuration?.
thank you
Nishant Savalia Mon, 04/15/2013 - 05:10
  • Bronze, 100 points or more
Hi Maximo,
Your configuration of COR list is not working because CME first checks the dial-peer 50 and then it checks for the another possibility of dialpeer which can be best match with the destination-pattern.
As per your configuration it will first block the call (pots dial peer 50) but it will through the call by dialpeer (voip 11).
You can try below methods:
1). If you want to use COR list then try to avoid overlapping pattern so that your cor list will work fine.
or
2). Create DN of the destination pattern and leave as it is (i.e. don't apply that DN anywhere)
Thank You,
Nishant Savalia
