anchoudh Tue, 03/20/2012 - 18:49
  • Red, 2250 points or more
Hi Asim,
Try using diferent browser.
Please restart the IIS service and check one more time.
Also check the MADM logs for this issue (you can attach the snapshot)
C:\Program Files\wfavvid\log\MADM
Hope it helps.
Anand
Please rate helpful posts..
anubhati Tue, 03/20/2012 - 19:28
  • Cisco Employee,
Try the following and see if it works
1. Open Internet Explorer and type http://crsIPAddress:6293/appadmin/
2. Login to appadmin and go to Control Center page.
3. Select the CRS Administration process radio button and click
the "Restart" button.
4. Exit the browser and launch appadmin normally from the Start Menu.
Alternatively, if this is an HA setup, login to appadmin from the 2nd node,
go to the Control Center page, select the broken node, and restart it's CRS
Administration process.
Anuj
