Bill Lundin Sat, 03/24/2012 - 12:02
Same here.  Working with a Dell Inspiron, about 1.5 yrs old, W7, Dual Core 2.2.  No updates seem available.  Please advise.
pbystrov Mon, 03/26/2012 - 03:49
Joining the club...
Same error - old graphics driver.
Updated the drivers through Lenovo Update untility, but that didn't help.
Please, advise.
RobertFee Wed, 03/28/2012 - 14:17
I downloaded the client tonight and have the same problem.  I'm running an HP laptop with 32 bit Windows 7.  All device drivers are up to date.  PC is about 18 months old.
jrandby Thu, 03/29/2012 - 06:08
Hi this is a known issue:
Jabber Video fails to install on Windows with the message: New features in this version of Jabber Video are not supported by your computer´s graphics driver.
To fix this, please try to use the Windows Device driver update, which should automatically install the newest graphics driver for your graphics card. If windows update does not find the correct driver, please visit the support/download page for the manufacturer of your laptop or display driver. E.g. if you have a Dell laptop with an Intel display driver, you should first check for the latest drivers from Dell, as they may be specific for your laptop, then check your graphics card manufacturer (typically ATI/NVIDIA/Intel).
Let me know how it goes
BR
Johan
pbystrov Thu, 03/29/2012 - 08:15
Hi Johan,
Done it by installing Lenovo System Update utility and updating the graphics driver - that didn't solve the issue unfortunately - same error.
miwilusz Mon, 04/02/2012 - 11:16
Jabber Video requires OpenGL 1.2+ support.  If you post your specific workstation and graphic card, I can help you dig around for the drivers.  You may have more luck downloading drivers directly from Nvidia or Intel.
-mike
pbystrov Mon, 04/02/2012 - 23:53
Thanks a lot MIchael!
I have Lenovo X201 laptop ThinkPad X201 (3626-BY4):
i5-520M(2.4GHz), 4GB RAM, 128GB Solid State Drive, 12.1in 1280x800 LCD, Intel HD Graphics, Intel 802.11agn wireless, WWAN option, Bluetooth, Modem, 1Gb Ethernet, UltraNav, Secure Chip, Camera, 6c Li-Ion
Windows 7 Enterprise, 64 bit
As I wrote earlier - Lenovo System Update was run, drivers were updated - but that didn't help.
I am also using Cisco PrecisionHD camera for video.
Please, advise for the best driver.
jrandby Tue, 04/03/2012 - 00:03
We have seen that Lenovo X201 has been successfully updated by using windows update and selecting the optional updates. Please try this. It is possible that the Lenovo system update is not using the latest drivers.
BR
Johan
John Faltys Fri, 09/28/2012 - 14:30
Have you had any success with Dell Inspiron 1545?
We have been running Movi/Jabber for the last couple of years.  It has been working fine up through 4.2.  4.4 will not install because of Jabber  Video fails to install on Windows with the message: New features in  this version of Jabber Video are not supported by your computer´s  graphics driver.
I see nothing in the release notes that indicate there are new requirements for video.  OpenGL 1.2 has been a long time requirement.  Are there new requirements?
jrandby Mon, 10/01/2012 - 03:45
OpenGL is a cross platform graphics framework used in Jabber Video to ensure a consistent cross platform experience. Jabber Video is using a small subset of OpenGL features, limited to the OpenGL 1.2 featureset, released in March 16, 1998. Between version 4.2 and 4.3 of Jabber Video (aka Movi), the OpenGL requirements changed due to an internal third party component upgrade (Clutter). Still, Jabber Video is only using the 1.2 featureset. The consequence of this is that a working Movi 4.2 on one computer may stop working on after upgrading to 4.3 (rebranded to Jabber Video) or later. You will see an error message asking to upgrade graphics driver. Failure to INSTALL Jabber Video will have to be troubleshooted, this issue will NOT affect the installation of Jabber Video. When Jabber Video is started, a small test is performed to check if the graphics functions are working. Some drivers result in a failing test, and the error message will be displayed. Restarting the PC or re-installing Jabber Video will not help, the only solutions are to upgrade the graphics driver or downgrade to Movi 4.2.
Affected users
We have seen that Lenovo computers with Intel chipset are prone to this problem. In most cases we can make Jabber Video work by changing to a newer driver. In cases where no updated driver is available because of special restrictions related to a laptop manufacturer, the only solution may be to stick with Movi 4.2.
How to identify
You can identify the graphics driver version by looking in the display information in control panel. Device Manager - Display Adapters - Mobile Intel 4 Series Express - Driver - Driver Version.
Example: Lenovo X200 and X201 running Win7 32-bit Mobile Intel 4 Series Express Chipset Family
  • 8.15.10.2021 released 14.12.2009 NOT OK
  • 8.15.10.2182 released 19.07.2010 OK
  • 8.15.10.2413 released 03.06.2011 OK
  • 8.15.10.2555 released 19.10.2011 OK
How to fix
  • If the driver version you have is NOT listed as OK above, try to upgrade your driver.
Windows Update
  • Many users report that they can use the Windows Update to get the latest driver. They need to enable "optional updated" in order to achieve this.
  • Other users report that Windows Update says "You have the latest driver", but can still resolve the issue by upgrading manually:
Manually Installing the Intel driver
BR
Johan
TheVeteran Tue, 03/19/2013 - 13:43
Here is my question.
How many computers have this situation and who are they?
Chris Swinney Thu, 03/21/2013 - 05:01
  • Silver, 250 points or more
There is also an ongoing issue with laptops that have multiple video chipset's and/or use the NVidia Optimus technology enabled in the BIOS.
The NVidia Optimus Technology allows for battery life extension yet maintain performance by switching video chipset and mange the GPUs.
Our Dell Latitude E6520 and E6420 laptops all use an inbuilt Intel HD Graphics 3000 chipset, plus a discrete NVidia 4200M card. We also utilise a docking station to enable the laptops to be use in a desktop environment. An external Tandberg PrecisionHD USB HD Camera or a Microsoft LifeCam is utilise via the docking station, and the laptops integrated webcam is utilised when away from the dock.
The issue comes when you switch from one mode to the other (docked/undocked). Without Optimus enabled, essentially the laptop see on the NVidia chipset and the switch from one camera to the other is relatively seamless. However, with Optimus enabled, Jabber simply hangs when it tries to connect the video feed.
Of course the later is highly irritating as the Jabber client will still be running in the background so will accept a call and then hang, meaning that you have to manually close the app, restart and then re-establish the call.
We notified Cisco (via our partner) of this bug over 2 years ago but unfortunately nothing has been done to resolve the issue. We have other applications that can take video feeds from the different cameras and continue to function correctly with Optimus enabled, so it is possible to program for such occurrences.
viniciusxp Tue, 08/05/2014 - 01:13
I was facing the same problem with a fairly new HP 840. It has two graphic cards, and Jabber gets lost with the switch. I've installed latest AMD Catalyst Control Center and had to add jabbervideo.exe and supportabilitytest.exe to the "High Performance" list of applications.
This way it uses the discrete graphics and does not switch from one to the other.
Now all works fine.
ksouthall Thu, 02/26/2015 - 08:58
I have this same issue, the thing is it works on one identical machine, but not another.
We have two DellOptiPlex 7010's,
Both had 2 instances of AMD Radeon HD 7470 - they are dual monitor machines.
In both cases the driver version 8.922.0.0, Driver Date 12/6/2011. This is the latest Dell has.
On one machine Jabber for TelePresence 4.4 works, on the other we get
"Graphics card or driver not supported!
New features in this version of Jabber Video are not supported by your computer's graphics driver.
Update to the newest graphics driver available and run Jabber Video again."
I can't believe it's just a matter of upgrading the drivers because in this case one machine with identical drivers works.
