RVS4000 Site to Site VPN Issue
Mar 21st, 2012
Hi all, I'm having problems with my VPN, the tunnel is up but I can not get to the far end, when I trace to an IP address at the far end it times out after it his my VLAN interface on my Switch.
Configurations are as follows:
RVS4000
Local Group Setup  Local Security Gateway Type:   IP Only
IP address: xxx.xxx.141.69
Local Security Group Type:  Subnet
IP Address:  192.168.4.8
Subnet Mask:  255.255.255.248
Remote Group Setup  Remote Security Gateway Type:   IP Only
Remote Security Group Type:  IP Addr
IP Address:  xxx.xxx.208.10
Remote Security Type: Subnet
IP Address: 172.16.0.0
Subnet Mask:  255.240.0.0
IPSec Setup  Keying Mode:  IKE with Preshared keyl
Phase 1:
Encryption:  3DES
Authentication:  SHA1
Group:  1024-bit
Key Life Time:   28800Sec.
Phase 2:
Encryption:  3DES
Perfect Forward Secrecy:  Disable
Group: 1024-bit
Status  UP
Switch Configuration
Vlan4                  192.168.4.14    YES NVRAM  up                    up
interface FastEthernet0/36
description *****WORKS NETWORK*****
switchport access vlan 4
switchport mode access
switchport port-security maximum 3
switchport port-security aging time 1
switchport port-security violation protect
speed 100
duplex full
interface FastEthernet0/44
description *****UPLINK TO RVS4000 WORK*****
switchport mode trunk
duplex full
     192.168.4.0/29 is subnetted, 1 subnets
C       192.168.4.8 is directly connected, Vlan4
C    192.168.5.0/24 is directly connected, Vlan3
     10.0.0.0/24 is subnetted, 1 subnets
C       10.50.50.0 is directly connected, Vlan2
C    192.168.3.0/24 is directly connected, Vlan1
S*   0.0.0.0/0 [1/0] via 192.168.3.254
Can anybody help with me connecting to my works 172 network please?
Many thanks
Martyn
jasbryan Wed, 03/21/2012 - 08:46
  • Silver, 250 points or more
Martyn,
We need the configuration from both sides of the tunnel. just displaying one side wouldn't give us enough information for a problem.
Most likely its not going to be a problem on the RVS4000 since we are have limited configuration/options we can change. if the other router is a enterprise device i would call tac and open a case. I had similar case where Cisco 871 had a asynchronous routing configured and was causing similar problem.
Looking at your traffic selection for the remote security group i see you using /12 which is a huge amount of traffic selection to send across the tunnel and would affect how Internet access to certain sites behind RVS. normally this will only include /24 maybe a /21 for larger networks.
Please provide more details so we can find a solution or point you in the right direction like opening a case with TAC.
Jasbryan
martynch1 Wed, 03/21/2012 - 09:55
Thanks for your reply, yes the other side is a ASA 5540, below is my configuration on there.
Local Network: 172.16.0.0/12
Remote Network: 192.168.4.8/29
Crypto Map
PFS Disabled
NAT-T: enabled
Time: 8.0.0 hh.mm.ss
Traffic Volume: 4608000
Ike Neg Mode: Main
Tunnel Group:
Ike Peer ID Validation: Required
Monitor Keepalives: 10 seconds intervals with 2 seconds retry
IPsec Protocaol: Enabled
Does this give you enough information or would you like to see other configuration settings?
Thanks again
Martyn
jasbryan Wed, 03/21/2012 - 10:02
Please give me copy of phase 1policy (IKE), phase 2 policy and ACL attached to your crypto map policy for the RVS4000. It’s best if we can see all information for tunnel.
You can mask public ip addresses.
What's your phase 2 key lifetime on RVS4000?
Jasbryan
martynch1 Thu, 03/22/2012 - 15:02
Sorry for the delay, mad day at work.
I hope this is the required info
access-list VLAN-773_Outside_81_cryptomap extended permit ip 172.16.0.0 255.240.0.0 192.168.4.8 255.255.255.248
crypto map VLAN-773_Outside_map 81 match address VLAN-773_Outside_81_cryptomap
crypto map VLAN-773_Outside_map 81 set peer 217.137.xxx.xx
crypto map VLAN-773_Outside_map 81 set transform-set ESP-3DES-SHA
tunnel-group 217.137.xxx.xx type ipsec-l2l
tunnel-group 217.137.xxx.xx general-attributes
default-group-policy lan2lan
tunnel-group 217.137.xxx.xx ipsec-attributes
pre-shared-key *****
group-policy lan2lan internal
group-policy lan2lan attributes
vpn-filter none
vpn-tunnel-protocol IPSec svc
If you require please let me know
Martyn
martynch1 Fri, 03/23/2012 - 08:56
Does this help you at all?
Thanks martyn
martynch1 Fri, 03/30/2012 - 09:05
Any further help on this would be great... thanks
jasbryan Fri, 03/30/2012 - 09:46
Marty,
I know the problem will be over on IOS router configuration as we have limited amount of information we can change in the small business. it would be good to get a case started with TAC and after they review settings have them to 3 way SBSC and we'll work together to get this issue resolved for you.
Jasbryan
