Warning message
Weird issue with ASA, can't configure interfaces
Answered Question
Mar 21st, 2012
  • Gold, 750 points or more
Got new ASA5550, code 8.2.2 in flash, can't configure "nameif" or "ip address" on the interfaces:
ciscoasa(config)# int gig0/0
ciscoasa(config-if)# ?
Interface configuration commands:
  default      Set a command to its defaults
  description  Interface specific description
  dhcp         Configure parameters for DHCP client
  duplex       Configure duplex operation
  exit         Exit from interface configuration mode
  help         Interactive help for interface subcommands
  no           Negate a command or set its defaults
  shutdown     Shutdown the selected interface
  speed        Configure speed operation
These are all the options that I get! Another weird thing I noticed is "<system>" string in "show ver" top line:
ciscoasa# sh ver
Cisco Adaptive Security Appliance Software Version 8.2(2) <system>
Compiled on Mon 11-Jan-10 14:19 by builders
System image file is "disk0:/asa822-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 27 mins 22 secs
Hardware:   ASA5550, 4096 MB RAM, CPU Pentium 4 3000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Has anyone seen this before?
Correct Answer by kampmalm2 about 5 years 5 months ago
That ASA is in multiple context mode.
Overall Rating: 5 (1 ratings)
Correct Answer
kampmalm2 Thu, 03/22/2012 - 00:04
Roman Rodichev Thu, 03/22/2012 - 08:45
You just made me feel like an idiot! Thanks a lot!
