Warning message
NetFlow and Cat4500E
Does anybody know which flows can be monitored in a Cat4500E with SUP7-E or SUP7L-E? Can I monitor every flow in the switch (e.g. flows between two ports on WS-X4648-RJ45-E card) or can I monitor only flows that pass the uplink ports integrated on the Supervisor Engine?
I’ve found something for a Cat3560-X and 3750-x (see below), but I can’t find any similar information for Cat4500E.
Q. Can I monitor every flow in my switch using the Service Module?
A. All flows that pass the uplink ports are supported. Flows that do not traverse the uplinks like the flows between two access ports on the same switch or switch stack are not supported at FCS.
Thanks for your help.
