03-22-2012 08:06 AM - edited 03-04-2019 03:45 PM
and
I'm looking to add ASR 1002s for my internet edge and I need 10GE interfaces on them. Is there a difference between those 2 I've listed?
03-26-2012 03:31 AM
LW stands for LAN/WAN. L is only LAN. The LW have WAN SONET capabilities, so if you are going to connect this to a 10G Ethernet switch, this are useless, buy only the LAN version.
Br
Alex.
03-27-2013 07:31 AM
From the datasheets, both support SONET
Both document contain : "
The Cisco SPA/SIP portfolio allows deployment of different interfaces (packet over SONET/SDH [POS], ATM, Ethernet, etc.)"
Only difference with WL is "
• WAN, SONET/SDH, dense wavelength division multiplexer (DWDM), and add/drop multiplexer (ADM) connectivity (WAN PHY mode)"
04-17-2016 02:02 AM
04-20-2020 07:51 AM
Hi Ahmed,
Sorry i know its an old query but just im curious to know if you try to connect SPA-1x10GB-L-V2 with OTV. DCI it looks extend the LAN which i think it should be ok. Could you share your experience.
Saeed
