Warning message
NAT problem on a HWIC trunk port
Mar 22nd, 2012
Hi all,
I have a Cisco 2811 with an additional HWIC-4ESW card.
Fe0/0 is my WAN port to the Internet
Fe0/1 is P2P link to another location
Fe0/0/0 is a trunk port to a Catalyst 2650 switch
Fe0/0/1 is also a trunk port to a Catalyst 2650 switch
Fe0/0/2 is a link to an MPLS network
I need to NAT anything heading out of the WAN port.
I have the following:
interface FastEthernet0/0
description WAN
bandwidth 10000
ip address 203.1.9.1 255.255.255.252
ip access-group ACLIN-TO_WAN in
ip nat outside
no ip virtual-reassembly
duplex full
speed 100
interface FastEthernet0/1
description MAN
bandwidth 4000
ip address 172.16.4.2 255.255.255.240
duplex full
speed 100
interface FastEthernet0/0/0
description LAN trunk
switchport trunk allowed vlan 1,2,103,1002-1005
switchport mode trunk
interface FastEthernet0/0/1
description DMZ trunk
switchport trunk allowed vlan 1,2,203,1002-1005
interface FastEthernet0/0/2
switchport access vlan 403
bandwidth 4000
interface FastEthernet0/0/3
shutdown
interface Vlan1
no ip address
interface Vlan103
ip address 10.0.24.1 255.255.255.0
ip nat inside
interface Vlan203
ip address 203.1.2.3 255.255.255.248
interface Vlan403
ip address 172.16.2.9 255.255.255.252
ip route 0.0.0.0 0.0.0.0 203.166.90.133
ip nat source list 101 interface FastEthernet0/0 overload
access-list 101 permit ip any any
I can ping anything connected to my other private networks from my 10.0.24.0 network but nothing on the Internet.
Nothing is getting translated.
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
  FastEthernet0/0
Inside interfaces:
  Vlan103
Hits: 0  Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Outside Destination
[Id: 1] access-list 101 interface FastEthernet0/0 refcount 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
Any ideas?
Thanks.
rsavena14 Fri, 03/23/2012 - 02:02
Have you tried adding inside from your configuration.
ip nat inside source list 101 interface FastEthernet0/0 overload
Eduardo Cesaro Fri, 03/23/2012 - 07:19
Yeah put the overload in the nat list
rsavena14 Sat, 03/24/2012 - 00:58
Hi eduardo,
its the inside command you try to add.
