Warning message
Jouni Forss Fri, 03/23/2012 - 04:36
I guess you mean the Cisco IPsec VPN Client?
When you insert a new connection configuration (remote host, group, group pass/key) to the VPN Client software it will create the configuration file to your computer.
You should be able the find a folder named "profiles" in the folder that you have installed the Cisco VPN Client into. It contains files for every connection you have configured on your VPN Client
You can copy this .pcf file to the same folder on some new users computer after they have installed the VPN Client. If you have the VPN Client open when you copy the profile file, you will have to restart the client to show it in the main window of the VPN Client.
- Jouni
