Warning message
Remove Standby WAAS Central Manager
Mar 23rd, 2012
We have 2 WAAS central managers in our deployment in different data centres.
The secondary has recently been removed as it was EOL and a new WAVE594 bought to replace it.
Unfortunately the old standby central manager is still listed in the primary central manager showing as Inactive.
We would like to register the brand new backup central manager with the primary central manager (using a new hostname but same IP) but as the old one is still in there we are unable to as we get the following error message when doing a "cms enable":
WAE594(config)#cms enable
Registering WAAS Central Manager...
Sending  device registration request to Central Manager with address 10.x.x.x
Registration record for this device already exists or other nodes share the foll
owing information with this node: Certificate hash already used by device xxxxx (CdmConfig_20188158); Mac 50:3d:xx:xx:xx:xx already used by device xxxxxx(CdmConfig_20188158); Ip address xxxxxxx#10.x.x.x already used by
device xxxxxxx(CdmConfig_20188158);
register: Registration failed(512).
cms: unable to register node
FAILED to enable management services
Please can someone advise how we can remove the old standby central manager from the primary so we can register it's replacement? Deleting it from the central manager GUI has no effect even after a reload it is still listed.
Many thanks, Paul
paulhawker Mon, 04/02/2012 - 07:53
Does anyone have any ideas at all on this?
Many thank, Paul
pevaneyn Sat, 04/07/2012 - 04:59
  • Cisco Employee,
Hi Paul,
If the old standby CM is still in the system I would do an identify recovery on the new hardware.
Mark the secondary CM as replaceable in the GUI, then do "cms recover identity" on the new standby CM.
This will give it the same IP and name, but that you can change afterwards.
Can you try tis?
Best regards, Peter
paulhawker Thu, 04/12/2012 - 04:14
Many thanks for the response.
We do use the identity recover procedure for replacing accelerators sometimes. Unfortunately it doesn't seem to be an option for standby central managers as the option to mark it as replaceable on the GUI is not there.
If you know a CLI method to mark the secondary central manager as replaceable I'd be glad to try it though but I think this method is only for accelerators.
Cheers, Paul
csebala_r1 Sat, 04/14/2012 - 07:52
Hi Paul,
Can you try this from new the device
"cms deregister force" and press Yes
paulhawker Thu, 04/19/2012 - 09:35
We have tried issuing the "cms deregister force" command from the new central manager but it will not accept it as it says it is not registered so this command won't work.
If we had the old central manager still I'm sure this command would do the job and then let us register the new one - but that's the issue - we don't have the old one anymore unfortunately...
Thanks!
pevaneyn Fri, 04/20/2012 - 03:49
  • Cisco Employee,
Hi Paul,
I think there is no standard way to fix this.
Please open a TAC case, and attach a sysreport of the new CM. The developers should be able to provide a script to fix the situation for you.
Best regards, Peter
prakashkblore_2 Tue, 07/02/2013 - 05:46
     I was able to register to CM after "cms deregister force". Thanks :-)
Prakash.K
