Warning message
Lobby Ambassador- Guest User Creation
Answered Question
Hi all,
I am currently implementing the use of the lobby ambassador for guest account creation, however I am looking to see if some features exist. I would like to be able to tie into AD to create lobby ambassador's to have further control of who can and cannot create guest accounts. I am also looking if there is a way to put restrictions on the time frame a guest account can remain active for when created by the lobby ambassador. An example of what I am trying to do is to not have a guest account created by an ambassador to go over a day for it's time frame.
Thanks in advance,
Chris
Correct Answer by Stephen Rodriguez about 5 years 4 months ago
Yes and yes. From WCS you can pull the role for lobby admin and use that to create the group with the proper attributes.
Then on the WCS you build the template you want them to use. There you can create the restrictions of how long.
Steve
Overall Rating: 5 (1 ratings)
Correct Answer
Stephen Rodriguez Fri, 03/23/2012 - 19:24
  • Purple, 4500 points or more
Steve
Trending Topics - Security & Network
