Warning message
ASA static NAT problem
Answered Question
Mar 23rd, 2012
Dear  boss
Please see attached my network diagram and following configuration.
interface Ethernet0/0
nameif local
security-level 100
ip address 192.168.0.243 255.255.255.0
interface Ethernet0/1
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.252
interface Ethernet0/2
nameif DMZ
security-level 50
ip address 172.29.1.1 255.255.255.0
access-list DMZTOLocal extended permit ip host 192.168.0.241 192.168.0.0 255.255.0.0
static (DMZ,local) 192.168.0.241 172.29.1.5 netmask 255.255.255.255
access-group DMZTOLocal out interface local
policy-map global_policy
class inspection_default
  inspect dns preset_dns_map
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
I get ping and access to 192.168.0.241(172.29.1.5) from 192.168.0.0/16, but cant get access and ping from 172.29.1.5 to 192.168.0.0/16.
what can i do if i want to get ping from DMZ to local ? ??
Please suggest me.
Thanking u
Shahid
Correct Answer by John Blakley about 5 years 4 months ago
Shahid,
The ASA/Pix firewalls allow you to go from a higher security level to lower security level by default, but blocks traffic coming the other direction. You'll need to add an acl on the dmz interface allowing the traffic into you local lan from the dmz.
As a side not, is there a reason that you're natting into the DMZ from your local side? You shouldn't if you can help it.
access-list FromDMZ permit icmp host 172.29.1.5 192.168.0.0 255.255.255.0
access-group FromDMZ in interface DMZ
John
Please rate useful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
John Blakley Sat, 03/24/2012 - 06:01
  • Purple, 4500 points or more
Shahid,
John
