Alternative platform for CUCM other than VMware
Mar 24th, 2012
Guys I was just wondering if there is another platform that I could successfully install CUCM ( Home-Lab purpose) on other than VMware. I was looking for a permanently free / open-source solution.
Any suggestions guys?
Cheers
Overall Rating: 3.5 (4 ratings)
gbljoba Sat, 03/24/2012 - 04:50
Why not VMware. There are free versions.
Sarg . Sun, 03/25/2012 - 02:07
could you provide me a link to a free version please? my work station evaluation has come to an end and vmware now requires me to pay for a license. I am not keen on doing that since this is just a home lab.
ronpatel Sun, 03/25/2012 - 00:40
  • Blue, 1500 points or more
For Virtulisation we only support vmware. You can either use MCS boxs or use Vmware.
regards
Ronak Patel
Please rate helpful posts.
Chris Deren Sun, 03/25/2012 - 14:11
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
The VMware server solution is a free platform.
heathrw Mon, 03/26/2012 - 03:17
  • Bronze, 100 points or more
You can run it on VMWare player but would recommended as per Ronak's post, ESXi on a dedicated which you can run for free (or full featured for 60 days) which is limited to the amount of CPU cores (6 from memory and the amount of ram).
But hardware is cheap you can run quite a lot even on an i5 processor and 16g RAM, thin provision. Just make sure you have an Intel CPU as well.
There are ways of using Sun's virtualbox to emulate VMWare hardware have done it but ESXi allows you to reserve the lower and higher limits of your CPU and RAM resources .
Heath
Sarg . Tue, 04/03/2012 - 15:35
All very great guys. Thanks so much. The VMware playing was the one I really needed.
Cisco forum; always helpful.
Cheers guys
