Warning message
One way communication happening from CCM 6.0 to CCM 8.0
Mar 26th, 2012
Dear All,
We have a intercluster trunk configured from CCM 6.0 to CCM 8.0; where some phones are registered on CCM 6.0 and other phones are registered on CCM 8.0.
When we call from phone registered on CCM 6.0 to CCM 8.0 call is happening and voice is flowing through the Trunk.
But when we try calling from phone registered on CCM 8.0 to CCM 6.0 sometimes the call is landing but voice does not flow and sometimes its just shows processing and call does not proceed.
( Both the CCM's are connected on the same zone without any firewall.)
Kindly Update what could be the problem.
Ranjit
gnanem Mon, 03/26/2012 - 05:28
  • Cisco Employee,
Do you have ICT from cucm 8.0 to 6.0?.
Gnaneswaran.
ronpatel Mon, 03/26/2012 - 05:41
  • Blue, 1500 points or more
HI
How is routing done to reach both the network.
regards
Ronak Patel
kusatija Mon, 03/26/2012 - 06:53
  • Silver, 250 points or more
Hi Ranjit,
Does same zone mean they are on the same LAN, i think what Ronak meant was what are the devices in between the clusters...
Can you post call manager traces with calling called party numbers from both nodes for a bad call.
Do you have an MTP box checked on Cucm 8 side on the trunk..?
Kunal
ranjit123 Mon, 03/26/2012 - 07:53
MTP box is unchecked
there is a core switch on which both the CUCM'S are connected.
ronpatel Mon, 03/26/2012 - 08:47
I was talking about ip routing, Just plain IP routing. As you said they are connected to core switch.
1) Do you have seperate VLAN for both the cluster. If yes Do you have proper routing between them.
2) Make sure you do not have any ACL applied between path.
Ronak Patel
kusatija Mon, 03/26/2012 - 09:47
Hi Ranjit,
Can you post a detailed call manager trace, with calling/called party numbers...
Kunal
ranjit123 Mon, 03/26/2012 - 21:41
Hi  Kunal Satija,
The Issue got resolved after a Hard Boot of CUCM 6.0 ( this step was taken after lots of troubleshooting)
This was the same remedy which was followed when the same issue had occured from our CUCM 6.0 & Notel Call Manager.
Ranjit
kusatija Tue, 03/27/2012 - 09:44
Hi Ranjit,
Great, thanks for keeping the post updated.
Kunal
