CSC Modules on ASA 5505 ?
Answered Question
Mar 26th, 2012
Hi Experts ,
Is it possible to install Content Security and Control (CSC) Modules on ASA 5505 ?
Or only AIP SSC-5 Modules are the only modules that can be installed on ASA 5505s ?
Please help !
Anup
Correct Answer by varrao about 5 years 4 months ago
Hi Anup,
CSC modules are only for ASA 5510,5520 & 5540, you can refer to the datasheet:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/product_data_sheet0900aecd802930c5.html
Hope that helps.
Varun
Cisco Endorsed by Nilo Noguera
varrao about 5 years 3 months ago
Hi Anup,
Yes, you are correct. If you do not have any issues replace the device, you can go for ASA 5510 or 5520 for better flexibility and performance.
Varun
Overall Rating: 5 (2 ratings)
Anup Sasikumar Sat, 03/31/2012 - 00:34
Hi Varun,
Thanks for the help. So IPS /IDS Module AIP SSC-5 is the only module I can put into an ASA 5505 .
Anup
varrao Sat, 03/31/2012 - 00:52
  • Red, 2250 points or more
Hi Anup,
Varun
Related Content
