IPSEC Remote Access VPN issues connecting to external interface
Mar 26th, 2012
Hello Community,
I am having issues with setting up a remote access connection to my external interface on my firewall.
I have used the ASDM wizard and followed all the proper instructions to set it up, but I cannot get a client to connect to it.
My laptop is connected to an external network, it is using the windows built in VPN plus the cisco vpn to test as well.
It will just keep trying to connect and it will just time out.
Anything you can suggest? I have setup LDAP which get a successful connection. I also tried local authentication to test too.
Thanks in advance!
