cisco WiSM LAG
Mar 26th, 2012
Dear all,
I have upgraded my 6500 switch and the configuration on the ports of the WiSM has been gone, i am unable to access those ports to join them to the port-channel.
i am trying to disable the LAG feature to be able to access the ports, but i am issuing the command
(Cisco Controller) >config lag disable
Incorrect usage.  Use the '?' or <TAB> key to list commands.
any idea.
thanx in advance
George Stefanick Mon, 03/26/2012 - 18:54
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Were your sups at SXH code level and you went tot SXI or above?
If you did and your config was manually done (not auto lag) they go poof, the config deletes once you go to SHI or above ... You need to do autoloag on your SUPs to fix this ...
Ma'moun Mohamma... Mon, 03/26/2012 - 19:01
many thanx for your reply.
actually this is exactly what happened.
so what to do now, and how to do the autoloag on the SUPs.
George Stefanick Mon, 03/26/2012 - 19:04
I knew I should have posted this blog post about this ... I will get that out this week..
Anyway, here I blogged about auto lag... You need to reconfig the WISM with autoloag. I blogged about auto lag  here ...
http://www.my80211.com/home/2009/11/20/wism-auto-lag-feature.html
Please rate helpful post ... I can tell you this tool me 6 hours to figure out and tested over and over again ...And opened 2 tac cases...
Ma'moun Mohamma... Mon, 03/26/2012 - 19:14
my friend,
actually i think that these commands are applied as follows:
wism module 11 controller 1 native-vlan 40
wism module 11 controller 2 native-vlan 40
wism module 11 controller 1 qos-trust dscp
wism module 11 controller 2 qos-trust dscp
and still i cant do nothing.
please advice
George Stefanick Mon, 03/26/2012 - 19:16
Well your commands are relevant to what vlans you have ...
What is your management vlan and are you tagging it ? Also what other vlans are you using ?
blakekrone Mon, 03/26/2012 - 19:46
  • Silver, 250 points or more
While those are correct you need to setup the WiSM service-vlan command as well.
wism module 11 controller 1 service-vlan
wism module 11 controller 2 service-vlan
without a valid service-vlan the WiSM's will not come up.
jlhainy Fri, 03/30/2012 - 20:16
I am having the same problem.  When I apply the commands for auto lag, it generates port-channels 400, but the po interfaces show as administrately down.  When I try to enable them, it doesn't recognize the port channels.
jlhainy Fri, 03/30/2012 - 20:49
Silly me.  I was untagging vlans when I shouldn't have.  My stuff is slowly starting to come back.
