Warning message
Analog Conference Station on VG224 unable to hold and conference
Mar 27th, 2012
Hello All,
My customer has 3 analog conference stations
ClearOne Max EX wired
Polycom Voicestation 300
Polycom Soundstation VTX 1000
These are connected to a VG224, added to the CUCM. for conferencing, Users should ideally place the first call on hold and then dial the 3rd number and conference. Users are unable to place the first call on hold and then dial a second number and then put the two dialled calls in conference.
Please provide some suggestions to troubleshoot this.
Abraham
Overall Rating: 3.7 (3 ratings)
kelvin.blair Tue, 03/27/2012 - 08:41
  • Silver, 250 points or more
Abraham,
Your VG224 will need to be setup as a SCCP gateway to CUCM.  Once you done this, please be sure to have this command in the system.
"stcapp call-control mode standard"
This will enable hookflash to work with conference phones.
cheers!
KB
abraham1982 Tue, 03/27/2012 - 08:51
Thanks a lot for your reply Kelvin.
In the VG224, this was the configuration
stcapp ccm-group 1
stcapp
stcapp feature access-code
I have added the command stcapp call-control mode standard under config t  but now when I do a show run I cannot see this command applied anywhere.
Am I missing something ?
Abraham
kelvin.blair Tue, 03/27/2012 - 08:57
Just means that it is enabled in the default router configuration and only doing a "no" will make it appear in the configuration.
add "stcapp supplementary-services" command
cheers!
KB
thomas-jensen Tue, 03/27/2012 - 08:55
I'm running IOS 15.1 and these could be some more helpful commands.
port 2/0
  hold-resume
voice-port 2/0
timeouts initial 60
timeouts interdigit 60
timeouts call-disconnect 0
timeouts ringing infinity
timeouts power-denial 2000
caller-id enable
abraham1982 Tue, 03/27/2012 - 09:09
Thanks again for the reply.
To add the command stcapp supplementary-services, I believe I have to get in to the ccm-group. But it is not allowing me to.
(config)#stcapp ccm-group 1
stcapp is running... unable to change ccm-group
Is there any other way to apply this command.
Abraham
abraham1982 Tue, 03/27/2012 - 10:23
Anyone has any idea how to apply the command stcapp supplementary-service in VG224. For me it gives the error
or If I try
(config)#stcapp supplementary-services
It is unrecognized..
Please help.
Abraham
thomas-jensen Tue, 03/27/2012 - 10:48
Try this
-vg08(config)#no stcapp
stcapp shutdown initiated... waiting for calls to clear.
stcapp shutdown complete.
vg08(config)#stcapp ccm-group 2
vg08(config)#stcapp ccm-group 1
-vg08(config)#stcapp
(config)#stcapp
