how to assign ipv6 to LAN.
hatman
Hi ,
Am just start to implement ipv6 to my network i want to know how to assign ipv6 to clients ?
now am set ipv6 on the router gateway at interface LAN only and then am check on a workstation
it can get ipv6 already this solution is correct or not?
which the best solution for assign ip address to a clients same as function dhcp ?
thank you.
Marcin Latosiewicz
Among most common solutions you will have:
- IPv6 RA (for pure address configuration) + DHCPv6 (for additional information), read about "managed" flag in RA.
- SLAAC - not every vendor implements it.
I have more question
how to assign dns-server , gateway , etc...
you can use stateless DHCPv6: http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-dhcp.html#wp1080090
Regards.
Alain
