anchoudh Tue, 03/27/2012 - 09:22
Hi Waas,
First you need to CLI into your Meetingplace Express box:
http://www.cisco.com/en/US/docs/voice_ip_comm/meetingplace_express/2_0/e
nglish/administration/guide/cm20cli.html
Next you have to sign in as an administrator and super user, su. After
that you need to run the date command:
*         Date MonthMonthDayDayHourHourMinMin
As you can see, it in two digit intervals, for example, if I want to
change the time from 6:00AM to 7:30AM of today date:
1.     Date 03120700
a.     March 12, 2009 7:00AM
2.     Date 03120730
a.     March 12, 2009 7:30AM
To change the time zone, please type in timezone and do the necessary
changes. As long as you do not change the date and time, you should be
okay.
Summary
The time zone command sets the Cisco Unified MeetingPlace system local
time zone.
Description
The timezone command sets the time zone used for CLI commands. It also
sets the local time zone for end users. The Cisco Unified MeetingPlace
system lists all the available time zones, by continent and city. Choose
the city that is in the same time zone as the local site.
Options
Bring up the following options by entering timezone:
1) Europe-Brings up a screen of time zones for Europe.
2) Far East-Brings up a screen of time zones for Asia and Australia.
3) North America-Brings up a screen of time zones for North America.
99) quit-Quits the timezone command.
Hope it helps.
Anand
Please rate helpful posts..
Wassim Aouadi Fri, 03/30/2012 - 06:24
the link you provided does not work. Can you post it again?
Can you elaborate on the exact syntax of the command?
[[email protected] mpxadmin]$ time zone
-bash: zone: command not found
real    0m0.001s
user    0m0.000s
sys     0m0.000s
[[email protected] mpxadmin]$ time ?
-bash: ?: command not found
real    0m0.001s
user    0m0.000s
sys     0m0.000s
[[email protected] mpxadmin]$ show timezone
-bash: show: command not found
Aaron Harrison Fri, 03/30/2012 - 06:33
On MeetingPlace Express I think most settings were accessed by running the 'net' command. It brings up a menu with various system settings.
It's been some time though..
Aaron
Wassim Aouadi Fri, 03/30/2012 - 09:02
Aaron, the net command allows to configure DNS, NTP, hostname,... but not the timezone.
[[email protected] mpxadmin]$ net
Running "sudo" to get root permission...
This is the MeetingPlace Express network configuration utility.
Up to the point where you save changes, it is safe to hit ^C to get
out at any time, in which case nothing will have changed.
1) List current configuration
2) Configure Ethernet port 1
3) Configure Ethernet port 2
4) Set host names
5) Set domain name
6) Configure DNS service
7) Configure NTP service
8) Done
Jacob Killoy Mon, 04/02/2012 - 13:30
To change the timezone:
-Log on to the MPE server as mpxadmin, then SU to root.
-Edit the "/etc/sysconfig/clock" file and change the name to match your desired timezone (Zone="America/New_York")
-Relink the "/etc/localtime" file to the correct timezone by "ln -s /usr/share/zoneinfo/America/New_York localtime" substituting your timezone file for  "America/New_York"
-Issue the reboot command for the changes to take effect. This will disconnect all users from any active conferences.
Hope this helps,
Wassim Aouadi Tue, 04/03/2012 - 01:51
Hi Jacob,
I did as you told, but after the reboot MPX shows the same timezone:
[[email protected] mpxadmin]$ date
Tue Apr  3 10:42:57 CEST 2012   <-- 10:42 should be 9:42
I tried to set it to CET timezone:
[[email protected] mpxadmin]# ls -l /etc/localtime
lrwxrwxrwx    1 root     root           23 Apr  3 10:00 /etc/localtime -> /usr/share/zoneinfo/CET
[[email protected] mpxadmin]# ls -l localtime
lrwxrwxrwx    1 root     root           23 Apr  3 09:37 localtime -> /usr/share/zoneinfo/CET
[[email protected] mpxadmin]# vi /etc/sysconfig/clock
ZONE="CET"
UTC=true
ARC=false
Any idea?
