encapsulation dot1q is not working?, 2600 Cisco router
Mar 27th, 2012
     I am trying to config a 2620 Cisco router to perform subintreface (F0/0.1) for Vlan Trunk Protocol, however when I try to configure the encapsulation dot1q, I continue to receive error massage with ^ symbol below the 'c' See below, the platform version is a 12.3(26) which should be acceptable to perform an (encapsulation dot1q). The Ethernet is a fast-Ethernet 10/100 port. I also try the ISL, I receive the same massage.
Can anyone suggest what could be the problem!!
Thank you all!!!!!
Router#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#int f0/0
Router(config-if)#no ip address
Router(config-if)#no shutdown
Router(config-if)#int f0/0.1
Router(config-subif)#encapsulation dot1q 1
^ % Invalid input detected at '^' marker. Router(config-subif)#
==================================================================================================== Router#show version
Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-I-M), Version 12.3(26), RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2008 by cisco Systems, Inc. Compiled Mon 17-Mar-08 15:23 by dchih ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1) Router uptime is 5 minutes System returned to ROM by power-on System image file is "flash:c2600-i-mz.123-26.bin" cisco 2620 (MPC860) processor (revision 0x600) with 28672K/4096K bytes of memory . Processor board ID JAD05440GAN (1508240486) M860 processor: part number 0, mask 49 Bridging software. X.25 software, Version 3.0.0. 1 FastEthernet/IEEE 802.3 interface(s) 1 Serial network interface(s) 32K bytes of non-volatile configuration memory. 8192K bytes of processor board System flash (Read/Write)
Router#
Router#sh flash
System flash directory:
File  Length  Name/status
1  7754580  c2600-i-mz.123-26.bin [7754644 bytes used, 633960 available, 8388604 total]
Router#
Reza Sharifi Tue, 03/27/2012 - 19:28
  • Cisco Designated VIP,
    2017 LAN
Is this 10Mb interface?
Dot1q is supported on fastethernet interfaces.
Leo Laohoo Tue, 03/27/2012 - 19:41
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
No Reza it's a FastEthernet.
Besides, there's a particular IOS which allows  Ethernet interface on a 2600 router to support 802.1q trunking.  Don't remember which particular version.
Leo Laohoo Tue, 03/27/2012 - 20:05
  • Hall of Fame,
    2017 LAN, Wireless
Yes.  The only thing I remember was that it has to be on a "T" train.  But yes, I think it's this IOS version.
jesserc68 Tue, 03/27/2012 - 20:07
Do you happen to know what IOS support the encapsulation dot1q? I follow the  link, Raze posted, however there wasn't no  specific IOS.
Jesse
Leo Laohoo Tue, 03/27/2012 - 20:13
  • Hall of Fame,
    2017 LAN, Wireless
1.  Your router has a FastEthernet so it supports 802.1q outright.
2.  Your IOS is newer compared to the 12.2(2)T.
Can you try the command "encapsulation dot1q 30"?
jesserc68 Tue, 03/27/2012 - 20:28
Router(config)# Router(config)#int f0/0 Router(config-if)#no ip address Router(config-if)#no shutdown Router(config-if)#int f0/0.1 Router(config-subif)#encapsulation dot1q 30 ? % Unrecognized command Router(config-subif)#encapsulation dot1q 30                       ^ % Invalid input detected at '^' marker. Router(config-subif)# jesse
Leo Laohoo Tue, 03/27/2012 - 20:38
  • Hall of Fame,
    2017 LAN, Wireless
Hey Reza,
I haven't played with the 2600 for 7 years but does Jesse here need a "T" train?
George Stefanick Tue, 03/27/2012 - 20:44
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
I have a 2621 and its Version 12.3(13) and I can sub interface with no problems...
its even older
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-IK9O3S3-M), Version 12.3(13), RELEASE SOFTWARE (fc2)
George Stefanick Tue, 03/27/2012 - 20:46
Did you enable ip routing ... ? I wonder if that has something to do with it ...
jesserc68 Tue, 03/27/2012 - 20:54
I'm not sure about enable ip routing, what is the config or procedure?
Jesse
George Stefanick Tue, 03/27/2012 - 21:05
Do a config t ip routing
If the command takes, then try your sub interfaces.. If it doesnt work, you need the IP code as pointed out above.
jesserc68 Tue, 03/27/2012 - 20:31
Here it once more, this is better then the one before
Router(config)#
Jesse
Nandan Mathure Tue, 03/27/2012 - 20:12
  • Bronze, 100 points or more
Could you paste the following output.
Router(config-subif)#en ?
I want to see what options its giving you.
Also how are you connected to the router? console?
jesserc68 Tue, 03/27/2012 - 20:24
I am connected through the console, Here are the output.
Router#config t
Router(config)#
Router(config)#
Router(config-if)#
*Mar  1 00:01:36.891: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state t o up
Router(config-if)#
Router(config-subif)#enc ?
Router(config-subif)#en?
Jesse
darren.g Tue, 03/27/2012 - 20:49
  • Silver, 250 points or more
Router#config t
Router(config)#
Router(config)#
Router(config-if)#
Router(config-if)#
Jesse
It's possible your feature set it not good enough to run trunking.
Trunking apparently requires a minimum of the IP PLUS feature set according to this document
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a00800949fd.shtml
table 2 shows a minimum IOS of 12.0(1)T and IPPLUS/IPPLUS on the 2620 - so your IOS revision is OK, but maybe your feature set is not.
You can figure which feature set you have by going here
http://tools.cisco.com/ITDIT/CFN/Dispatch?act=rlsSelect&task=search&searchby=image
and entering your image name (assuming it's not been stuffed with) which you can find by doing "show flash" or "dir"
If you don;t have the right feature set, then you're out of luck unless you can upgrade/change the IOS image the router is booting with.
Cheers.
jesserc68 Tue, 03/27/2012 - 21:29
     I believe you are correct, I followed your link and inserted the IOS #c2600-i-mz.123-26.bin, the outcome  was c2600-i-mz.123-26.bin  12.3(26)  2620-2621  IP,
Therefore I believe I need an IOS the has the feature of IP PLUS. Is there any way you could inform me what IOS has the IP PLUS.
Jesse
darren.g Tue, 03/27/2012 - 21:47
Jesse
The image you need is C2600-is-mz.123-26.bin, and it's the last release for this model router that I can find. If you've got a service contract/CCO account, you can probably download it - but I expect you'll be breaching licensing conditions if you do. On your own head be it if you do!
Cheers.
jesserc68 Wed, 03/28/2012 - 06:32
Thanks for the info on the IOS, once I receive it and implement it I will let you all know if that was the issue.
Jesse
Nandan Mathure Tue, 03/27/2012 - 20:56
Is this the only command thats not working? if not live could u try different commands under interface? what configuration do u have under "line con 0" ?
jesserc68 Tue, 03/27/2012 - 21:16
Everything works except the encapsulation dot1q
George Stefanick Tue, 03/27/2012 - 21:20
When you say everthing thats a pretty open statment ... Did you post your config ?
George Stefanick Tue, 03/27/2012 - 21:21
also did you add the ip routing command ? If so what happen?
jesserc68 Tue, 03/27/2012 - 21:37
I config the ip route as you inform me but the encap dot1q still didnt work.
Router(config)#ip route ?
A.B.C.D  Destination prefix
profile  Enable IP routing table profile
static  Allow static routes
vrf      Configure static route for a VPN Routing/Forwarding instance
Router(config)#ip route profile ?
Router(config)#int f0/0.1
jesse
George Stefanick Tue, 03/27/2012 - 21:43
ip routing ....
rythem007 Tue, 03/24/2015 - 16:54
hi,
i have 2600xl router
it has also same problem of encapsulation command not working
i am stuck now.
what to do??
have you got any solution??
thanks
RUSTOM BILLIMORIA Wed, 03/28/2012 - 01:38
Dear jesse rodriguez
I just downloaded and verified your IOS a few mins ago from the Cisco Site. The ios indeed does not contain the Encapsulation command. Strange that it does allow us to create a subinterface but not assign an encapsulation.
Without the encapsulation command , I assume that we cannot assign an Ip address , hence the only solution is to change the IOS.
HOpe this Helps
Cheers!!
Rustom Billimoria
jesserc68 Wed, 03/28/2012 - 06:27
I just spoke with a friend and they are well to get the IOS C2600-is-mz.123-26.bin, once I implement the new IOS I will let you all know.
Jesse
xyra_basilio Thu, 03/27/2014 - 01:39
May we know if C2600-is-mz.123-26.bin fixed the issue and allowed the router subinterface for encapsulation?
JB
Nawaf Al.Mutairi Wed, 03/28/2012 - 10:33
So the problem is the IOS version ..!
I'm going to inform my IT group about it
Because we are going to make a lab with routers and switches
I found this post useful somehow
debnathgayatri Mon, 02/24/2014 - 13:55
I have the same error on the cisco 2612 router, version is 12.1(19).
rythem007 Tue, 03/24/2015 - 23:06
Related Content
