Problems configuring Access Server on Cisco 2509 router
Mar 27th, 2012
I am having trouble trying to configure my cisco 2509 cisco router for access server.  I have two guides shown below:
http://www.thebryantadvantage.com/CCNACCNPHomeLabAccessServerTutorial.htm
and
http://www.freeccnaworkbook.com/labs/section-1-getting-started-with-your-cisco-lab/lab-1-4-configuring-a-cisco-access-server/
However I am running into some problems.  I can go through the second guide up until it asks me to do this command
Step 5: Configure the transport input protocol on the async lines to Telnet.
Access_Server(config-line)#transport input telnet
I cannot put in Transport Input,  I only have the option of doing Transport Output let me show some lines from my console:
Access_Server(config)#line 0 14
Access_Server(config-line)#no exec
Access_Server(config-line)#transport input ?
% Unrecognized command
Access_Server(config-line)#transport ?
  output     Define which protocols to use for outgoing connections
  preferred  Specify the preferred protocol to use
Im not sure whats going on.   I have two routers(cisco 2600 series) plus my 2509 cisco router I am going to use for a access server.  I have a two switches 2950 series and I have the access server connected to all of them via a octal cable.
Here is the configuration from the access server:
IOS (tm) 2500 Software (C2500-IS-L), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 14:39 by dchih
cisco 2509 (68030) processor (revision M) with 14336K/2048K bytes of memory.
Processor board ID 22840809, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
8 terminal line(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
Its probably the weakest router I have the others have much more memory.
I set up everything in that post for my access server but the transport input as I could not execute that command here is some more info:
Access_Server#show host
Default domain is not set
Name/address lookup uses domain service
Name servers are 255.255.255.255
Codes: UN - unknown, EX - expired, OK - OK, ?? - revalidate
       temp - temporary, perm - permanent
       NA - Not Applicable None - Not defined
Host                      Port  Flags      Age Type   Address(es)
R1                        2001  (perm, OK)  0   IP    10.10.10.10
Access_Server#R1
Trying R1 (10.10.10.10, 2001)...
% Connection refused by remote host
Access_Server#
As you can see when I try to connect to R1 which is my router it refuses... I am confused as the guides say I should be able to connect.
I went ahead and added SW1 as well:
SW1                       2002  (perm, OK)  0   IP    10.10.10.10
As you can see though it also refuses I thought it might be the cable to trying to test connectivity
Access_Server#SW1
Trying SW1 (10.10.10.10, 2002)...
Access_Server#
I just found this link from this site as well which I will also review as it is detailed instructions on setting up access server.  Please help with answers however,because I will post if I figure this out and I am type personality that never stops till I figure out what I am after lol...uggggg
http://www.ciscopress.com/articles/article.asp?p=27650&seqNum=5
I just ran a running config that I got from the above link from cisco press:
Access_Server#show running-config
Building configuration...
Current configuration : 614 bytes
version 12.3
hostname Access_Server
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip host R1 2001 10.10.10.10
ip host SW1 2002 10.10.10.10
interface Loopback0
ip address 10.10.10.10 255.255.255.255
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
ip http server
ip classless
line con 0
exec-timeout 0 0
no exec
line 1 8
line aux 0
line vty 0 4
end
Access_Server#
Not sure if any of this information helps.
I went ahead and turned off the power on the 2509 access server and turned it back on here is the full information it gave then, and I am guessing its removed all the previous info:
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Bridging software.
8 terminal line(s)
% Please answer 'yes' or 'no'.
Would you like to enter the initial configuration dialog? [yes/no]: no
Would you like to terminate autoinstall? [yes]: yes
Press RETURN to get started!
*Mar  1 00:00:10.907: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
*Mar  1 00:00:10.911: %LINK-3-UPDOWN: Interface Serial0, changed state to down
*Mar  1 00:00:11.279: %LINK-3-UPDOWN: Interface Serial1, changed state to down
*Mar  1 00:00:28.659: %PARSER-4-BADCFG: Unexpected end of configuration file.
*Mar  1 00:00:29.655: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0,
*Mar  1 00:00:45.831: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, c
*Mar  1 00:01:18.747: %IP-5-WEBINST_KILL: Terminating DNS process
*Mar  1 00:01:20.267: %LINK-5-CHANGED: Interface Serial0, changed state to admin
istratively down
*Mar  1 00:01:20.331: %LINK-5-CHANGED: Interface Ethernet0, changed state to adm
inistratively down
*Mar  1 00:01:20.335: %LINK-5-CHANGED: Interface Serial1, changed state to admin
istratively down
*Mar  1 00:01:21.335: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, c
*Mar
Router> 1 00:02:11.191: %SYS-5-RESTART: System restarted --
*Mar  1 00:02:11.199: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing
a cold start
Router>enable
Router#
Brian Catlin
wilder7bc Tue, 03/27/2012 - 20:19
Ok that link helped me move forward a little bit.
Before I could not do Transport input  I think I found some connection to it.
IN the post that Reza listed the author states this:
"To use a terminal server we need a 2509/2510 8 lines or 2511/2512 16 lines router and 1 or 2 octal cables."
So mine only has 8 lines so I thought I will try 1-8 instead of of 0-14 which my router said was the limit, and instead of 1-16 which the other guide used which I could never do because it was a different type of router.
So once I put in the 1-8 I now have transport Input as an option:
Access_Server#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Access_Server(config)#line 1 8
  input      Define which protocols to use when connecting to the terminal
             server
This is my first night back to work on cisco stuff and CCNA stuff but I have been trouble shooting for almost 15 years just new to networking as I am use to helpdesk and desktop tech stuff that I have picked up on jobs and toying around over the years.
Will continue to work on this and see if I can get through it now that I finally can do the transport input part!
Ok I got further here is my console:
Access_Server(config-line)#line 1 8
Access_Server(config-line)#exec-timeout 0 0
Access_Server(config-line)#end
Access_Server#
*Mar  1 00:40:04.619: %SYS-5-CONFIG_I: Configured from console by consoleR1
Trying R1 (10.10.10.10, 2001)... Open
*Mar  1 00:01:51.315: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing
a cold start
Router>enable
Router#conf t
Router(config)#hostname Access_Server
Access_Server(config)#ip subnet-zero
Access_Server(config)#no ip domain-lookup
Access_Server(config)#ip host R1 2001 10.10.10.10
Access_Server(config)#ip host SW1 2002 10.10.10.10
Access_Server(config)#ip host R2 2003 10.10.10.10
Access_Server(config)#ip host SW2 2004 10.10.10.10
Access_Server(config)#int ?
  Async              Async interface
  BVI                Bridge-Group Virtual Interface
  CTunnel            CTunnel interface
  Dialer             Dialer interface
  Ethernet           IEEE 802.3
  Group-Async        Async Group interface
  Loopback           Loopback interface
  MFR                Multilink Frame Relay bundle interface
  Multilink          Multilink-group interface
  Null               Null interface
  Serial             Serial
  Tunnel             Tunnel interface
  Vif                PGM Multicast Host interface
  Virtual-Template   Virtual Template interface
  Virtual-TokenRing  Virtual TokenRing
  range              interface range command
Access_Server(config)#int l ?
  <0-2147483647>  Loopback interface number
Access_Server(config)#int l 0
Access_Server(config-if)#ip address 10.10.10.10 255.255.255.255
Access_Server(config-if)#no ip directed-broadcast
Access_Server(config-if)#exit
Access_Server(config)#int eth 0
Access_Server(config-if)#no ip address
Access_Server(config-if)#shutdown
Access_Server(config)#int ser 0
Access_Server(config)#int se 1
Access_Server(config)#ip classless
Access_Server(config)#no ip http server
Access_Server(config)#line con 0
Access_Server(config-line)#logging synchronous
             server
Access_Server(config-line)#transport input all
Access_Server(config-line)#line aux 0
Access_Server(config-line)#line vty 04
Access_Server#
*Mar  1 00:14:16.127: %SYS-5-CONFIG_I: Configured from console by console
Name/address lookup uses static mappings
R2                        2003  (perm, OK)  0   IP    10.10.10.10
SW2                       2004  (perm, OK)  0   IP    10.10.10.10
Access_Server#R1
Access_Server#
but its stuck there and nothing is happening...uggg  so got a little bit further
Ok I had to restar after the last time because it just remained stuck never moving past trying to connect to R1 here is a copy from my console:
a cold start
Router>enable
Router#conf t
  Ethernet           IEEE 802.3
  Null               Null interface
  Serial             Serial
             server
Access_Server#
Access_Server#R1
Its just stuck again trying to connect.... not sure whats going on.
Ok here is the 2600  router that I have 2001 plugged into I ran  a running config on it.
Router#show running-config
Current configuration : 577 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router#
Its just blank router so should work I would think.  Not sure if I can test the cable but the cable is brand new out of the package.
wilder7bc Tue, 03/27/2012 - 21:10
I followed the post you gave above:
http://ciscotips.wordpress.com/2006/06/26/configuring-a-cisco-router-as-a-terminal-server/
It does not work when I try that I get the following:
*Mar  1 00:02:51.303: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing
a cold start
Router>enable
Router#conf t
Router(config)#ip address 10.10.10.10 255.255.255.255
% Invalid input detected at '^' marker.
Router(config)#ip address ?
Router(config)#int l 0
Router(config-if)#ip address 10.10.10.10 255.255.255.255
Router(config-if)#ip R1 2001 10.10.10.10
Router(config-if)#ip host R1 2001 10.10.10.10
Router(config)#ip host SW1 2002 10.10.10.10
Router(config)#telnet 10.10.10.10 2002
Router(config)#exit
Router#
*Mar  1 00:07:12.183: %SYS-5-CONFIG_I: Configured from console by consoleconf t
Router(config)#exit
Router#
*Mar  1 00:07:27.643: %SYS-5-CONFIG_I: Configured from console by console
Router#telnet 10.10.10.10 2002
Trying 10.10.10.10, 2002 ...
Router#
wilder7bc Tue, 03/27/2012 - 21:56
I have erased my config file on my switch 1 as well and then I started over on my config file for my access server
Router>enable
Router#conf t
Access_Server(config)#ip host r1 2001 10.10.10.10
Access_Server(config)#ip host sw1 2002 10.10.10.10
Access_Server(config)#ip host r2 2003 10.10.10.10
Access_Server(config)#ip host sw2 2004 10.10.10.10
Access_Server#
*Mar  1 00:04:49.255: %SYS-5-CONFIG_I: Configured from console by console
Access_Server#copy running-c?
running-config
Access_Server#copy running-config ?
  ftp:            Copy to ftp: file system
  null:           Copy to null: file system
  nvram:          Copy to nvram: file system
  rcp:            Copy to rcp: file system
  running-config  Update (merge with) current system configuration
  startup-config  Copy to startup configuration
  system:         Copy to system: file system
  tftp:           Copy to tftp: file system
Access_Server#copy running-config startup-config
Destination filename [startup-config]? y
%Error copying nvram:y (Invalid argument)
Access_Server#
[OK]
Current configuration : 680 bytes
version 12.3
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
interface Loopback0
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip http server
ip classless
line con 0
line 1 8
exec-timeout 0 0
no exec
line aux 0
line vty 0 4
end
Access_Server#sw1
Trying sw1 (10.10.10.10, 2002)... Open
Its stuck there doing nothing I guess I can go to bed and see if its finally gets through in the morning.  I dont know what else to do I have tested my router and now my switch.  I can get to both of them through the console cable but the access server does not seem to be letting me through.  My configuration seems to be fine on the access server as I have followed the directions.  I dont know how to test the octal cable but its brand new.  I just bought this access server and set it up the server seems to be fine when you log in via the console cable but thats about as much as I can tell.  I am exhausted from working all day then coming home working on this till 12 at night. I dont know where to go with this. The cursor is blinking on the terminal console but thats all it does I can hit enter or control Z and nothing happens it just continues to blink like its stuck there.
I did find this post where something similiar happened and it was with the cable
https://learningnetwork.cisco.com/thread/4382
I am going to cut the binder from it as it was rolled up and make sure no electromagnetic interference is happening from being rolled up and also start checking all 8 of the cable ends as well as try to connect to an end that is not plugged in to test see if that freezes up.
Ok I found out how to get back to the access_server  by doing the following:
To do so hold ctrl and shift, hit 6, release all keys, then hit X. From the access server you can then open new connections or resume connections that you already have open.
So hopefully this should speed up my testing.
*Mar  1 00:13:24.879: %SYS-5-CONFIG_I: Configured from console by console
r1                        2001  (perm, OK)  0   IP    10.10.10.10
sw1                       2002  (perm, OK)  0   IP    10.10.10.10
r2                        2003  (perm, OK)  0   IP    10.10.10.10
sw2                       2004  (perm, OK)  0   IP    10.10.10.10
Access_Server(config)#ip host r1 2008
% Incomplete command.
Access_Server(config)#ip host r1 2008 10.10.10.10
Access_Server(config)#exit
r1                        2008  (perm, OK)  0   IP    10.10.10.10
Access_Server#
*Mar  1 00:14:06.227: %SYS-5-CONFIG_I: Configured from console by console
[Resuming connection 1 to r1 ... ]
still freezing when I go back after changing
wilder7bc Tue, 03/27/2012 - 22:39
Ok my first success.  I was able to connect to octal cable 2007 when I plugged it into the switch.   So looks like its a bad cable and so far 7 is a good cable.... So looks like making some headway here I need to test that 7 on the router to and then see if I can find any other good cable ends and contact back the seller who sold me this....
Ok octal male Rj45 end number 2003 seems to be good.  So this would confirm the cable  is bad but I will double check to make sure first by checking the bad ends again.
just to update this post for anyone that may have the same problem in the future I will give some more information.
I contacted the company today where I bought the router and cable they where very helpful and are sending me replacements and paying for the shipping.  In addition the company owner stated that its probably not the cable that usually when this happens its the router, though just to be sure he is sending an extra cable. He did say the cable he had sent previously was brand new.  He also stated he had a router at his place of work that did the same thing, not sure if it has to do with the ensync serial type connection on the 2509 or something else.  I will upate this again when  I get the new router and cable and can test eveything.
wilder7bc Wed, 03/28/2012 - 00:31
Ok my finally testing is over I think.  My octal cable was bad 3, 4, 6, 7, 8  are good with 8 being a bit iffy...     1,2, 5 being bad.
I will need to contact the guy I bought this from.  1 I thought worked for a bit but when I tried it another time it did not work... so either the cable ends or cable its on is iffy or who knows what.  I know I got it working now using 7, 3, 4, 6.
one crazy night but learned a ton.
Scott Burrows Wed, 05/02/2012 - 09:05
Having the same exact issue with my 2509 router as well. I'll have to test out my octal cable to see if any of the others cables are working.
Did the new Router/Octal cable resolve your issues?
