Inbound SIP calls issues
Mar 27th, 2012
I been experiencing some weird behavior from inbound SIP calls. Outbound works great..
Ok this the dilemma. The calling party don't get a ring back while the called party rings. Called party picks up and the call drops after 10 seconds, in the mean time if the calling party don;t hang up the phone the called phone start ringing again as a new call where in fact the calling party never disconcerted the call.. This can continue all day in a loop if the calling party don;t hang up..
I hope i did explain it correcly.. This is some of the logs: If someone can give me any hints of what could be wrong greatly appreciated..
.Mar 28 01:42:37.829: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3475780000@x.x.x.x:5060 SIP/2.0
Reason: Q.850;cause=86
Date: Wed, 28 Mar 2012 01:41:59 GMT
Timestamp: 1332898957
Content-Length: 0
User-Agent: Cisco-SIPGateway/IOS-12.x
To: "347570000" <sip:3475700000@x.x.x.x>;tag=as525083e9
Call-ID: 02d32716428add3450773fe80e6fdb70@x.x.x.x
Via: SIP/2.0/UDP 192.168.1.26:5060;branch=z9hG4bK1343D256D
CSeq: 101 BYE
Max-Forwards: 70
.Mar 28 01:42:41.828: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:347500000@64.154.x.x:5060 SIP/2.0
Timestamp: 1332898961
Content-Length: 0
To: "34757800000" <sip:3475780000@64.154.x.x>;tag=as525083e9
Call-ID: 02d32716428add3450773fe80e6fdb70@64.154.X.X
CSeq: 101 BYE
Max-Forwards: 70
.Mar 28 01:42:45.828: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3475700000@64.154.X.X:5060 SIP/2.0
Timestamp: 1332898965
Content-Length: 0
To: "347570000" <sip:347570000@64.154.X.X>;tag=as525083e9
CSeq: 101 BYE
Max-Forwards: 70
.Mar 28 01:42:49.827: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3475780000@64.154.X.X:5060 SIP/2.0
Timestamp: 1332898969
Content-Length: 0
To: "3475700000" <sip:3475780000@x.x.x.x>;tag=as525083e9
CSeq: 101 BYE
Max-Forwards: 70
.Mar 28 01:42:53.827: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3475784000@x.x.x.x:5060 SIP/2.0
Timestamp: 1332898973
Content-Length: 0
To: "3475780000" <sip:3475780000@64.154.X.X>;tag=as525083e9
CSeq: 101 BYE
Max-Forwards: 70
Senthil Kumar Sankar Wed, 03/28/2012 - 06:09
The logs are incomplete. Also brief the call flow like what are components involved in the call flow
Senthil
Paolo Bevilacqua Wed, 03/28/2012 - 06:07
Maybe mention system type and version you have, and the exact complete call flow on all devices traversed.
love2xlr8 Wed, 03/28/2012 - 06:52
Paolo,
My mistake, CME 7.1 on 2801 router 12.4(22)YB8..
Call flow PSTN-SIP Provider-CME 7.1- Cisco Phone7970..
love2xlr8 Wed, 03/28/2012 - 17:01
Never mind- Got it.. It was a nat-ing issue.. got it to work.. Thank you guys!!
Marwan Urabi Fri, 04/06/2012 - 16:30
HI.
try add this commnand under service voip .
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
Best Regards
Marwan Urabi
love2xlr8 Thu, 04/12/2012 - 08:46
Marwan I dont have that option ip address trusted list.. I'm running CUE 7.1 btw..
Marwan Urabi Thu, 04/12/2012 - 10:27
HI,
before 2 month i use CME 4.1 on Router 1760 and this conifg is work for me .
voice rtp send-recv
voice service pots
supplementary-service qsig call-forward
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.7
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
sip
  registrar server expires max 3600 min 3600
after i upgrade to 8.5 on router 2811 , i have this problem and i solve it like this :
voice rtp send-recv
voice service pots
voice service voip
qsig decode
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server expires max 1200 min 660
i dont know if the ip address trusted list command avilable on CME 7.1,
Please check also 2 command under SIP
if is not work ,  please post your sample config and i will compare it with CME 4.1 i have it to .
Best Regards
Good Luck
Marwan
love2xlr8 Sun, 04/15/2012 - 07:09
2801CME(conf-voi-serv)#ip address ?
% Unrecognized command
Looks like its not..:)
