Warning message
Radius with user privileges
Mar 27th, 2012
hello
i have a question.. i am building a test network en i want to be able to control the users
and with control i mean i want to be able to make sure that the can't delete the flash:
or the flash:vlan.dat
is there a way to to this with a windows 2008 R2 server..?
also what are the difference in privileges levels lets say:
level 1
or
level 2
and so on
thanks
Eduardo Aliaga Sat, 03/31/2012 - 20:11
  • Silver, 250 points or more
You can perform "command authorization" by using a TACACS servers like Cisco ACS.
Privilege level is a legacy tool to also perform "command authorization" but it's way better to use a TACACS server for that.
Please rate if it helps.
johan oosterwaal Sun, 04/01/2012 - 12:03
Yes this helps allot THANKS!
I can do some testing with this TACACS
But i have lookt at some information about the server. But i can't seem to find, if its possible to limit the user to some commands en disable delete commands
Eduardo Aliaga Mon, 04/02/2012 - 13:38
If you have Cisco ACS 5.x you can use "command authorization sets" . There's a free trial of Cisco ACS 5.x so you can test it even if you haven't purchase it.
Please rate if it helps . Kind regards
