Warning message
How EX90 ver TC 4.1 register CUCM 7.1.5 ?
Answered Question
Mar 28th, 2012
Does anyone kno how EX90 ver TC 4.1 register CUCM 7.1.5 ?
CUCM 7.1.5 version can not upgrade, you can play what patch?Orthe EX 90 can be upgraded to version support CUCM 7.1.5.
Is there a perfect solution?
Thank you
Correct Answer by Alok Jaiswal about 5 years 4 months ago
Hi Zhang,
The native registration support for Ex90 and lot of other video endpoints has started with CUCM version 8.6 and later.So you can try registering but that won't be a native SIP registration.
You can try below steps for the registration.
1. Create a SIP digest user and associate it with the third party sip.
2. Add SIP third party device endpoint (advance).
3. Set all necessary field such as Device Pool, Location, Line (Partition & CSS), SIP Profile, Device Security Profile.
If the above doesn't works and if you are only looking for calling purpose you can also go with the SIP third party (BASIC).
adittionaly check another thread realted to your problem.
https://supportforums.cisco.com/thread/2083453
Alok
Overall Rating: 5 (1 ratings)
Correct Answer
Alok Jaiswal Wed, 03/28/2012 - 20:07
  • Silver, 250 points or more
Hi Zhang,
Alok
xingxing zhang Wed, 03/28/2012 - 20:56
Alok Jaiswal, thank you very much
The link you gave is also very useful
I'm actively trying to do
