Warning message
High Total output Drops
Mar 28th, 2012
Our database server is connected on cisco swich 2960G
gigabitEthernet 0/38.while showing the interface command the total output drops is a large value..Is there any issue with this value.I think this is one of the reason for slow access of the server.
pls give me a sloution....
cisco6#show interfaces gigabitEthernet 0/38
GigabitEthernet0/38 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 58bc.2746.45a6 (bia 58bc.2746.45a6)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 4/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2237384
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 18822000 bits/sec, 1636 packets/sec
  5 minute output rate 412000 bits/sec, 576 packets/sec
     359269545 packets input, 484444472380 bytes, 0 no buffer
     Received 20556 broadcasts (1757 multicasts)
     0 runts, 1 giants, 0 throttles
     198 input errors, 197 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1757 multicast, 0 pause input
     421979270 packets output, 43694459621 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Thanks &Regards
Sihanu N
Leo Laohoo Wed, 03/28/2012 - 21:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
No other line errors.
I'm suspecting the remote end cannot process the amount of data the switch is pushing.
You can either try QoS or you could try to lower your link speed to see if the output drops decreases.
Sihanu N Wed, 03/28/2012 - 22:17
Thanks for the reply.For database operation how I enable QOS,what is the command  for the same.
Thanks&Regars
Sihanu N
Leo Laohoo Wed, 03/28/2012 - 22:27
  • Hall of Fame,
    2017 LAN, Wireless
Let's try something easy:  Try lowering the link speed to 100 Mbps and see if the output drops stop or decreases.
Vasileios Boulo... Wed, 03/28/2012 - 23:55
  • Silver, 250 points or more
I suggest to clear the counters of the interface since
with the clear counter interface gigabitEthernet 0/38
Then check the CPU of the 2960 to check if the dropped packets are due to high cpu
sh proc cpu
sh proc cpu history
Vasilis
Sihanu N Thu, 03/29/2012 - 00:21
Thanks for your reply ,I clear the couter and tahke the cpu usage
cisco6#show processes cpu history
    1111111111111111111111111111111111111111111111111111111111
    2221111111111000000000022222111110000011111222221111100000
100
90
80
70
60
50
40
30
20
10 **********************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    2443133122132234221122211101121122211712213111112112022332
100
90
80
70
60
50
40
30
20                                      *
10 ##########################################################
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    1353324262432334243222342432222233333232133223343345432228313224244272
    7994629655882192323538612457448205761741924982178122913345197166844507
100
90                                                          *
80                                                          *
70         *                                                *          *
60   *     *                                                *          *
50   *   * * *                                    *   **    *     *    *
40  ** * * * **  ** *    ** **      ***           ** ***    *  *  * ** *
30  **** ****** *** *** *** ***  * *******  *************   ** * ********
20 **********************************************************************
10 ######################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
Tx&Rgds
Sihanu N
