UCCX 7 Desktop Administrator Enterprise fields not showing
Answered Question
Mar 29th, 2012
We are trying to configure Enterprise fields in the Desktop Administrator , however i can only see workflows and workflow configuration but no "Enterprise Configuration", any clue ?
when i open the Admin link for the Desktop Administrator, i get the application Cisco Desktop Workflow Administrator
Correct Answer by anchoudh about 5 years 4 months ago
CDAUI1000
Text: Error while trying to load data. Ensure that the
system path includes the location of the
WebAdminLib.dll.
Type: Fatal
Add’l Info: Error indicating that the location of the
WebAdminLib.dll is not added to the System path.
Action: On the Unified CCX server, add the location of the
WebAdminLib.dll (C:\Program Files\Cisco\
Desktop\bin) to the Path environment variable.
1. In Control panel, launch the System utility.
2. On the Advanced tab, click Environment
Variables.
3. From the list of system variables, select Path
and click Edit.
4. In the Variable value field, locate the string
C:\Program Files\Cisco\Desktop\bin;
and, using cut/paste, move it to the
beginning of the variable value string. This
results in the DLL being accessed from the
correct location.
5. Click OK and close the System utility.
6. Stop the Cisco Unified Node Manager.
7. On the Unified CCX server, delete the
teamadmin folder from these locations:
C:\Program Files\wfavvid\
tomcat_appadmin\webapps
tomcat_appadmin\work\catalina\localhost
8. Restart the Unified Node Manager, and wait
two minutes.
9. Access Cisco Desktop Administrator and
verify that you can navigate to the Services
Configuration > Enterprise Data > Fields
page.
Reference:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/reference/guide/cad66ecd.pdf
Hope it helps.
Anand
Please rate helpful posts, by clicking on the stars below the answers!!
Try opening the below url, replce the ip address 10.78.94.101 by your UCCX ip address.
http://10.78.94.101:6293/teamadmin/login.cda
Please lte me know the outcome.
Hope it helps,
Anand
Please rate helpful posts!!
Overall Rating: 5 (3 ratings)
anchoudh Thu, 03/29/2012 - 02:36
  • Red, 2250 points or more
Please select the Call Center in the CDA (Cisco Desktop Administrator), and navigate to Desktop Administrator->Side A , to open the Web CDA , login here, bavigate to Service Config->Enterprise data->Fields or Layout list
Hope it helps,
Anand
Please rate helpful posts by clicking on the stars below the right answer !!
f.hayeck Thu, 03/29/2012 - 03:22
i a trying to do that, but wehn pressing Side A, the application freezes for 10 to 15 seconds and nothing happens, then i can navigate in the workflow administrator
f.hayeck Thu, 03/29/2012 - 03:43
i am now able to access the Desktop Administrator, but it shows "
CDAUI1000 Error while trying to load data. Ensure  that the system path includes the location of the WebAdminLib.dll."  when trying to access Services Configuration > Enterprise Data > Fields or Layout List
Correct Answer
anchoudh Thu, 03/29/2012 - 03:56
CDAUI1000
WebAdminLib.dll.
Type: Fatal
Variables.
and click Edit.
correct location.
two minutes.
page.
Reference:
Hope it helps.
Anand
anchoudh Thu, 03/29/2012 - 05:03
Hi Hayeck,
Glad to know that :-) and thanks.
Anand
Related Content
