Warning message
DID on E1 PRI ISDN
Mar 29th, 2012
Dear All,
I want to configure DID on E1 PRI
I configured the PRI as follows and I need help to configure the DID on it.
isdn switch-type < primary-net5 >
controller e1 0/2/0
framing <crc4>
linecode < hdb3 >
pri-group timeslots < 1-31 >
paolo bevilacqua Thu, 03/29/2012 - 03:45
  • Hall of Fame,
    Founding Member
Have you ever configured voice before? Do you know about things like dial-peers, translation-rules, etc.?
Because if you don't, the best is that you engage a reputable professiona or UC certified Cisco partner for the job.
George Moussa M... Thu, 03/29/2012 - 03:56
Yes, I know the dial-peer very well and I put the bellow configration of DID and didn't work
dial-peer voice 1 pots
corlist outgoing local-VM
description ** Inside Cairo **
destination-pattern 9[2-9].......
incoming called-number .
direct-inward-dial
port 0/2/0:15
forward-digits 8
Even I put connection plar 100 on the voice-port 0/2/0:15 to send all the incoming calls to the secrtary office, when I remove this command any one calls the company a message tells him that this number is not correct and when I put it back it rings !!
also I tried these configrations and fail
voice translation-rule 1
  rule 1 /^226492/ /2/
  exit
voice translation-profile pstn-in
  translate called 1
  exit
voice-port 0/2/0:15
  translation-profile incoming pstn-in
ronpatel Thu, 03/29/2012 - 04:04
  • Blue, 1500 points or more
HI
What is the DID number you are hacing and send us debug voip ccapi inout and ISDN q931 output.
regards
Ronak patel
